i'vw got an greddy profect b-spec 2, a gt35/40, with cheap 50mm jjr waste gate that i bought from just jap, and i have tried so many ways to hook the boost control and done the way greddy booklet says boost controller to top of gate and a tee before it to the bottom of the gate. and can only get it to run a psi which the spring in the gate is, tied a couple of other ways and i cen either get to 30+ psi and wont stop or 8 psi nothin in between, im kinda leaning towards the boost conteol not working, i cant realy get any voltage to the solonid with the controller turned on is this right???? it maybe gets .02 of a volt, i've put the solonid to 12 volts and it click ok so thats ok................. doesnt anyone know wats going on is it the cheap gate f**king me around or the boost control....i want about 16psi.............. any test i should do... please HELP i've spent about 4 hours on this thing and dont even talk about the fuel....
If you followed the book to the letter then should be ok. I have this one and it is perfect. You may have to turn your gain down if it is spiking uncontrollably. Try 10 on the gain and set gain should be 4lbs below the boost you have it set at. If working on 10lbs boost then "boost set" should be at the percentage it takes to reach that boost with gain at 10 and set gain at zero. Once you achieve the 10lbs boost slowly turn up the "set gain till spiking occurs then turn it down 2lbs. Then turn up your "gain" till spiking occurs then turn that down two clicks, that should do it. Then get a tune for God's sake as boost will be coming on much lower in the rev range. After tune fine tune one or two clicks higher or lower.
all ok now, had to use the solonid like a internal gate should be and hook it to the bottom of gate and just a normal pressure to the top and now works fine. thanx anyways
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
