Good day fellas,
I just went down to Calder last nite and ran a personal best of 13.06 @ 108mph in my rb20det R32 Gtst...
Car was running 18psi and was making around 210rwkw...was on hankook rs2 street rubber and was in full street trim...didn't even pull out the spare tyre...
I'm so agonisingly close to a 12 on street rubber and trim but getting that extra 0.06 seconds will probably be too much for my poor little engine...we'll see though...it might just eat away at me too much and i might give it another go after summer if she's still alive and kicking then...
Cheers...
Edited by limpus
https://www.sau.com.au/forums/topic/195900-ran-a-130-on-my-rb20det-r32/
Thats the problem...damn calder print outs yesterday didn't show 60ft times...i was aiming to monitor those times...
In terms of mods...its got all the usual bolt on support mods like exhaust, fmic, remap, injectors and runs a hks2535...made 217rwkw at 19psi in winter at dr drift's dyno...still have some restrictions in the system which i might aim to sort out over the coming months...
Edited by limpus
2535 isnt gonna make mountains more than that.
Maybe another 20rwkw or so.
I was running 109mph/12.9 with a car a bit over 1400kg and 210rwkw myself with a 2.160ft
Just need some more traction and you should be able to pull that down to a 12.8/12.7
Practice makes perfect, and you have a nice set-up there, love the 2530/2535 for the RB20. Great turbo :)
Spewing...
I have some nice 'street tyres' here you could have borrowed... 235 semi comps :)
Lolz Sam...then they wouldn't be street tyres would they...
By the way sam...the car is still hitting a flat spot on hard shifts...can we try to sort that out sometime?
if those are the 'street' tyres i'm thinking of then i can vouch that they've spent their whole life on the street :)
i get the same thing with the flat spots - need to add fuel to those points on the map. Yours is a remap yeah?
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
    • More photos are up, and the price has been dropped to $16,000. It's just had a service and a new 12V battery, too.
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
