Hey,
I made a couple posts in the "car not accellerating propperly" thread, but still having problems with my car. It's a 1990 R32 gts-t
Here are my current modifications:
pod filter
3" cat-back exhaust
FMIC
Here is my problem:
When the car is hot, if i accellerate hard, the engine pops and misfires at about 3500rpm. Only happens under load and only when i've been driving for about 5 mins or so and it's nice n warm.
Here's what i've done so far to try and fix it:
Upgraded fuel pump to one from an R33 GTR
New spark plugs
Replaced coils with 2nd hand ones from another 32 gts-t
Not sure what's going wrong.. seems like it's a fuel or ignition problem, but i can't quite tie it down. I put in a fuel mixture display kit from Jaycar to see if it was rich or lean when it spits n pops, but the lights just flash from lean to rich and back over n over again.
I'm pretty much out of ideas. Maybe i need to upgrade coils. Maybe i should try regapping the spark plugs.. i really don't know anymore.
Any advice or suggestions would be greatly appreciated. May end up that i'll just have to take it to a garage with a dyno to get it diagnosed. better start saving my $$
https://www.sau.com.au/forums/topic/195931-car-problems/
put in an autotechnica fuel pressure regulator.. i don't recommend them.. crappy cheap parts, broke in a couple places, but managed to get it working in the end.
fuel pressure was only 35psi when idling.. upped it to 60psi at idle and seems to have fixed the problem.. more testing (aka fanging it) needed, but signs look good.
Thanks Gaz n Pal for the suggestions.
https://www.sau.com.au/forums/topic/195931-car-problems/#findComment-3509249
try a new air flow meter.....
my afm was dicky when the car got hot and i did all the usual 'obivous' quick fixes such as
-changed my igniter module
-changed all 6 coilpacks
-put in new plugs and gapped them to .6mm
-changed air filter and changed fuel filter
problem ended up being the air flow meter was faulty.... give ben at KYP a call
Edited by Pandaah32
https://www.sau.com.au/forums/topic/195931-car-problems/#findComment-3515414
hahaha.. maybe you can donate me the cash mr engineer sir.
but yeah.. me n Steve found tonight that my coils are arcing onto the block seems the "new" coils were about the same condition as the old ones. gonna araldite them and reduce the plug gap.. should do the trick.
https://www.sau.com.au/forums/topic/195931-car-problems/#findComment-3518287
I've got a set of standard 32gtst coils doing nothing other than taking up space.. they were working well enough to make 245rwhp on the RB20 :nyaanyaa:
Or a set of splitfired aren't too pricey, I got mine for $515 delivered I think it was.
https://www.sau.com.au/forums/topic/195931-car-problems/#findComment-3518768
ok this is really annoying me now.. problem is still happening with araldited coils and spaller plug gaps.. gonna try air flow meter next.. Were you getting the same symptoms when your airflow meter was faulty Pandaah?
next to try after that will be ignition module.. how do i go about testing that?
Edited by Wogan
https://www.sau.com.au/forums/topic/195931-car-problems/#findComment-3520809
another thing i find interesting is that my car is making about 12psi of boost without a boost controller installed.. inspected the wastegate actuator and the hose feeding it, but they seemed fine. The previous owner hadn't done much work to the car and didn't have a working boost gauge.
could it be that i'm getting too much boost and the standard ECU is cutting the fuel?
https://www.sau.com.au/forums/topic/195931-car-problems/#findComment-3520822
borrow one from someone else or throw it on a dyno for a full diagnostic run
if your running stock ecu they can check what the prob is if they have the software
https://www.sau.com.au/forums/topic/195931-car-problems/#findComment-3520849
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
