Hey guys just recently got a non-turbo r33 and last night cracked the lower part of my front bar pretty much in half goin up a little enbankment (scrubbed out)
i live on the gold coast and i was just wantin some advice on how and where to get it fixed
and prices on a stock front bar with paint.
any help is appreciated
https://www.sau.com.au/forums/topic/195973-r33-front-bar-damage/
Hi mate, firstly sorry to hear you accidentally damaged your frontbar... never mind mate, it can be fixed... perhaps post up some pictures so we can see the degree of damage and advice on how much it'll cost to get fixed and what will be involved...
If it's cracked in half like you had briefly, the bar will have to be patched up, primed, prepped and repainted from scretch... if it is this severe, you should get a new front bar and get it painted... probably work out similiar...
Post up pictures mate....
Regards,
Kevin
Cant post any pics up atm cos its currently at a workshop gettin a few problems ironed out and hopefully the bar can get fixed under warranty as one of the clips holding it was actually broken wen they sold it to me.
If it comes down to it and i have to get a new front bar (payed for by me) i will be looking for one that doesnt sit so low to the ground any estimations on prices (cheapest possible)
Thx
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
