i have a number of items that i'm looking to get rid of from an R33. Need to minimise my loses. Happy for local pick up or i can courier at purchasers cost. Negotiable on some items so just ask.
Located in Noosa on the sunshine coast (QLD)
PH: 0411967856
Items:
R33 Crank angle sensor - $75
R33 power steering pump - $140
R33 power steering resevoir - $50
R33 engine mounts X2 (good condition) - $60 each
R33 airflow meter - $120
R33 Climate control unit out of series 2- $100
R33 front door hinges X 4 & bonnet hinges X 2 - $20 the lot
R33 auto instrument cluster - 83XXX km on odometer SOLD
R33 S1 type M RHS front bar grill piece - $15
R33 S1 type M RHS front bar indicator - $35
R33 heater core in heater unit - $80
R33 interior fan in housing - $40 SOLD
R33 Aircon components - complete set up - $175
R33 Auto tail shaft - front and rear - $50 for both
Charcol canister - $30
R33 Combination switch (wiper/indicator) - $40
R33 fan shroud - $50
R33 radiator with temp sender switch - $150
R33 brake master cylinder - $40 SOLD
R33 brake power booster (S2) - $60
R33 windscreen washer bottle (washer motors not working) - $40
R33 front castor rods - pair (bushes in very good condition) - $50 each
R33 radiator over flow bottle - $40
R33 viscous fan (some small cracks in plastic) - $35
R33 RHS front lower control arm with balljoint - $80
R33 RHS front wheel bearing/hub/upper control arm assembly - $175
R33 LHS front wheel bearing/hub/upper control arm assembly - $175
R33 front brake calipers (not siezed) - to be sold as pair - $315
Edited by Riceburnerowner
  • Replies 40
  • 2 months later...
  • 3 weeks later...
willing to sell just the heater core off the unit if so how much please.
Also is it in good condition the heater core.?
cheers
Allan.M
