i have a number of items that i'm looking to get rid of from an R33. Need to minimise my loses. Happy for local pick up or i can courier at purchasers cost. Negotiable on some items so just ask.
Located in Noosa on the sunshine coast (QLD)
PH: 0411967856
Items:
R33 Crank angle sensor - $75
R33 power steering pump - $140
R33 power steering resevoir - $50
R33 engine mounts X2 (good condition) - $60 each
R33 airflow meter - $120
R33 Climate control unit out of series 2- $100
R33 front door hinges X 4 & bonnet hinges X 2 - $20 the lot
R33 auto instrument cluster - 83XXX km on odometer SOLD
R33 S1 type M RHS front bar grill piece - $15
R33 S1 type M RHS front bar indicator - $35
R33 heater core in heater unit - $80
R33 interior fan in housing - $40 SOLD
R33 Aircon components - complete set up - $175
R33 Auto tail shaft - front and rear - $50 for both
Charcol canister - $30
R33 Combination switch (wiper/indicator) - $40
R33 fan shroud - $50
R33 radiator with temp sender switch - $150
R33 brake master cylinder - $40 SOLD
R33 brake power booster (S2) - $60
R33 windscreen washer bottle (washer motors not working) - $40
R33 front castor rods - pair (bushes in very good condition) - $50 each
R33 radiator over flow bottle - $40
R33 viscous fan (some small cracks in plastic) - $35
R33 RHS front lower control arm with balljoint - $80
R33 RHS front wheel bearing/hub/upper control arm assembly - $175
R33 LHS front wheel bearing/hub/upper control arm assembly - $175
R33 front brake calipers (not siezed) - to be sold as pair - $315
Edited by Riceburnerowner
  • Replies 40
  • 2 months later...
  • 3 weeks later...
willing to sell just the heater core off the unit if so how much please.
Also is it in good condition the heater core.?
cheers
Allan.M
    • Hi Rob It's a nistune ecu. Yes same shop, good reputation. Apparently the computer on the dyno is compensated for temperature.    Chris was saying that the lean or richness of the mixture would be covered in the actual tune, but he's already picking up in advance that it's under what it should be. Regards the dyno, it's also noticeable on the road. But I just want to add something that has just come in, it appears there might be something in the setup of the external wastegate. In the exhaust manifold there is a centre divider between the front three and rear three cylinders. The external wastegate has a pipe from each side that join at the wastegate. Theory is those two pipes just might be pypassing that divider and introducing a problem somehow. Is anyone familiar with the divider in the exhaust manifold and the effects if the two wastegate pipes were to create a bypass path? Thanks for your questions Rob, interested in your thoughts on this external wastegate bypass theory. Regards Rob
    • Meh, At 60 years old, I have been doing dumb stuff for much longer than you mate, I am the true King And unfortunately I cannot be a maroon, as I am not brownish red As for not getting ITB's, the plenum intake will apparently show typical gains across the board and increase induction noise a bit, but, have all over less dort than ITB's Cost difference for the extra ITB dorts was significant though, the total parts for the plenum set up is "around" $2kAUD plus shipping, the ITB's were $4kAUD plus shipping, I was contemplating really hard about paying the extra $2k for all of the dorts, but weirdly, some form of common sense, from listening to the platform experts prevailed  As for the NA mod hate by some, I've had a few boosted cars, with all their inherent issues, I'm now looking at simplicity and legalities for a street car, maybe I'm just getting old, and I'm quite happy to spend some of the kids inheritance, 5kw at a time 馃ぃ And think of all the money I'll be saving on consumables that something with boost needs, like engines, gearboxes, diffs, clutches,  tilt trays... etc. etc. etc. 馃お
    • Haha.  I wouldn't say I am either but I've definitely been around it plenty.  I'm guessing you know the dial in is basically to make a handicap to level the playing field between racers.  The car with the slower dial in goes first and in theory if they run their dial in time and the faster car also does then they cross the finish time if they also have exactly the same reaction time - if you go faster than the dial in them you lose, but if you are too slow there's a good chance the other person will get to the finish line first. I'm normally supporting other cars but they were all pretty dialled and were egging me on to race as well, here's one of the cars I tune (Starlet) which ran within like 1 hundredth of its dial in through the competition: https://www.youtube.com/watch?v=inEBu-d9Gn4&t=69s
    • Where ever the fuel reg gets it reference is what I use to T into for map reference been a very long time so where it goes to plenum/runners I have no idea but never had issues.
    • What ecu? Same shop every time? Same ambient temperature? If timing is correct then pull plugs and see if lean or rich. Dyno can also read different if they have changed ramp rate or not set tacho/speed properly
