R33 Parts - Lots Of Items - Check It Out
i have a number of items that i'm looking to get rid of from an R33. Need to minimise my loses. Happy for local pick up or i can courier at purchasers cost. Negotiable on some items so just ask.
Located in Noosa on the sunshine coast (QLD)
PH: 0411967856
Items:
R33 Crank angle sensor - $75
R33 power steering pump - $140
R33 power steering resevoir - $50
R33 engine mounts X2 (good condition) - $60 each
R33 airflow meter - $120
R33 Climate control unit out of series 2- $100
R33 front door hinges X 4 & bonnet hinges X 2 - $20 the lot
R33 auto instrument cluster - 83XXX km on odometer SOLD
R33 S1 type M RHS front bar grill piece - $15
R33 S1 type M RHS front bar indicator - $35
R33 heater core in heater unit - $80
R33 interior fan in housing - $40 SOLD
R33 Aircon components - complete set up - $175
R33 Auto tail shaft - front and rear - $50 for both
Charcol canister - $30
R33 Combination switch (wiper/indicator) - $40
R33 fan shroud - $50
R33 radiator with temp sender switch - $150
R33 brake master cylinder - $40 SOLD
R33 brake power booster (S2) - $60
R33 windscreen washer bottle (washer motors not working) - $40
R33 front castor rods - pair (bushes in very good condition) - $50 each
R33 radiator over flow bottle - $40
R33 viscous fan (some small cracks in plastic) - $35
R33 RHS front lower control arm with balljoint - $80
R33 RHS front wheel bearing/hub/upper control arm assembly - $175
R33 LHS front wheel bearing/hub/upper control arm assembly - $175
R33 front brake calipers (not siezed) - to be sold as pair - $315
Edited by Riceburnerowner
  • Replies 40
  • 2 months later...
  • 3 weeks later...
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
