Hey lads, im new to skylines, just got a question about 2 cars, im looking into getting a r32 or a r33 turbo, both are stock, what Mods would I have to do to get these cars into the mid 13s? front mont exhaust, bov? bigger turbo? soz for the newbie questions, I just havent delt with Turbos before as previous cars have been NA,
Cheers guys
Molloy.
https://www.sau.com.au/forums/topic/196002-newbie-skyline-questions/
hey mate, do a search of the forum it will provide all the information you will need.
also build your car up slowly, till your confident, a turbo car doesnt react/drive the same as a NA car :)
some items you'd need off the top of my head would be, full exhaust, fmic, fuel pump, piggy back ecu, good tune. all the parts you buy are only as good as the tuner your using :D
i was at eastern creek last week and i ran a 14.4 but also there was a s2 which he had said it was stock which i couldn't see any mods, didn't have a intercooler or anything like that had the factory SM, he ran a 13.7 stock, i think it may be that he is just a good driver
well to get into the mid 13's i dont know about much but to get to some power close to 200 rwkw yeah i can help ya there...i have a r33 s1 gtst...and i have over 200 rwkw on 10psi boost....atm i have returned to stock boost and i am still making 180rwkw....i have done the basic mods of front mount intercooler, full exhaust, clutch and coilpacks....good luck
Don't waste your money on a bov.
All you need is an exhaust + dump pipes etc. (2nd hand will do, find at a jap importer/wrecker, 3.5" will be big enough - no canons please!) and a A'pexi power FC/Greddy E-manage. Get it tuned by someone reputable. Stock cooler is fine for stock boost, maybe if you can get a cheap GTR intercooler that would be the cheapest way to get into high 13's. Then you'll be looking at new clutches, tyres.
If you spend a little more, FMIC will do the trick, boost controller (stock turbo doesn't like being boosted though), fuel pump when you get past 200kw.
Keep in mind its not all about power, driver skill/reaction and good suspension and tyre choice will get you over the line.
Just see how you got adding one thing at a time.
stock car:
Lower rear tyre pressures, find a good launch point and away you go.
add exhaust, repeat
add ecu, away you go.
    • Well some mostly good news and some slight bad news.  Good news is cylinder 6 did in fact only require a honing and I'm good to run my 86.5mm pistons again. I should also get the block back by end of week. Bad news, had a few surprises pop up. First, main and rod bearings were trashed. No sign of any heat damage. I knew right away what caused this... I had not packed my oil pump originally and spent a lot more time than I would have liked cranking the motor to get oil pressure. It sounded fine once started so I chucked it up to luck and forgot about it. Luckily rod and crank are fine and just need new bearings. Engine builder agreed that this was the cause.    Another surprise that carbon covered up very well that I didn't catch, something got sucked up and went through cylinder 1, 2 and 3. Luckily this was no cause for concern, just needed a bit of cleaning up. Valves look fine but he will vacuum test the head this week to confirm. I'm presuming this was something left over from welding my intercooler piping, but we'll never know. I'm going to thoroughly reclean everything.    So all in all, happy the motor is fine, and I'll get it back much sooner than expected. I'll also be taking the time to convert my WMI system over to direct port. I'll snap some pictures of that when the parts come in.
    • I understand, thanks. Yeah I wouldn't want the car to tip over, I'll try and use the sills, I don't want to risk smashing the chassis rails. I ordered some rubber pucks that have a hopefully big enough slotting. If the front right gives me trouble I can always just make a wood block. I'll measure and inspect the sills closer once I actually take the car up. I hope so, but the rubber blocks I had in hand so far were pretty damn firm, if they are that hard they won't give much way. I'll let you know what happens. Angle grinding rubber isn't one of my favorite tasks. I'll probably start a build thread soon, for my own documentation and "log" as well as sharing what's going on with the car.
    • Kinda something I have been thinking about.  To be honest, we bought it already driving like that.  So there's no telling how long it actually has been driving like this.  Hopefully damage is too bad when we drop the pan.   I am having a hard time finding a site that sells the solenoid for the 5 speed auto, do you have any suggestions?
    • That'll be most likely down the road...  LOL
    • a stock / option or aftermarket?
