hey i was thinking about getting my 32 engineered for my full cage cause i figured since i do use it for street as well it would bail me out of plenty of trouble but was just wondering what the exact process is, like what do they inspect etc etc and how much would i be looking at?
thanks guys
https://www.sau.com.au/forums/topic/196007-engineering-cert/
Depending on the cage, who made it, and if it was made to VicRoads specifications will determine if you can Engineer it or not.
If it really is a full cage, then probably unlikely.
See here to get you going.
http://www.vicroads.vic.gov.au/NR/rdonlyre...265/0/VSI28.pdf
thanks guys
i got my current car engineered - it was and had...
86 'Mazda familia wagon
1.6 turbo conversion
bigger brakes front and rear
front mounted intercooler and piping
later model 323 seats
bigger wheels
and all the other jazz that goes with an engine conversion
cost me 480~?? and that was a flat price
the guys name is Sanjay and he comes to your house
his number is 0402 407 839
he was good and gave me a list of things that needed the fix up
give him a call
sorry for the knob question but what is the point of getting an engineers certificate cant cops still put canarys on your car?? (by the way not being a smart ass serious question)
yeah i get what ya mean i guess
the shit (but good this was) after getting my engineers cert i havent been pulled over ( in 1.5 years) before i did my engine convserion and all the work i was pulled up 13 times in 8 months - the car was stock with a 2.5'' muffler THATS ALL!!!!!!
that 13 times includes 3 times in 1 easter weekend! LOL!!
as the other bloke said it may not stop you from being defected but MOST cops do acknowldge if you ahve taken the time and money to get it done by the book - which in the end is the way things have to be taken
Engineers covers the mechanicals.
Motor swaps, upgraded brakes/suspensions, gearboxes etc
Defects generally are things totally unrelated to a engineers like tyres, intake mods (x2), boost controllers etc.
So really unrelated to engineers signoffs
But im wondering here, if your vehicle is engineered with one intake mod, its completely passed. Can you then have your one intake mod after the engineered one? And fight it on a technicality?
No you cannont.
It clearly states in the EPA Guidelines that you are only allowed ONE intake mod.
So if you have two, then you will get pinned.
Its upto YOU to know the laws surrounding modifications with various gov't bodies.
13 times in 8 months huh?
what's your licence record like?
no offence, but do you drive like a dickhead?
    • From there it is trickier. Ecutek seems to be one of those closed ecosystems where everyone password protects their tunes which means I either choose a tuner and can't change from them and can't make any changes myself for any reason, or I have to buy the tuning software (about $4k) and then get someone to tune from scratch (which is not simple with all the multi dimensional tables these days). Once you buy about 300 "flash points" per ECU you can get it tuned and add their "RaceROM" function which hacks extra functionality like launch control onto the ECU, and also makes extra data available for logging over CAN Not sure what I'll do there yet; I'm tempted to use one of the overseas shops that does billions of remote tunes of the platform instead of starting from scratch locally, a lot can be done online these days.
    • Can I log IAT eh? Well, can now So next thing was looking at data logging. Not straight forward because none of the motorsport displays have cracked the nissan/inifinti CAN and ECU based displays don't do g logging, lap timing, predictive laps etc.  So, I bought an Ecutek dongle from Tunehouse (Oz distributor). Even without a tune onboard that allows display and logging of about 50 parameters via Android (and presumably iOS) app. Approx 600 for the bluetooth + Usb version That gives me (pretty ugly but) functional dash display on Android And logging of these parameters I'll play around a bit over the break, but at least now I can make sure I have oil pressure when I get to some track testing.
    • I don't know what globes/headlight connector they run, but I'd be looking for a female adapter to plug into the existing headlight on one side. Something like this https://www.ebay.com.au/itm/256017245989 Then I'd use a pair of single input, double output relays (one for low, one for high), mount them in a spare space in the fuse box if you want to to look more original (and be easier to maintain). Then 2 new power sources from the main stud in the fuse box via a fuse to each relay. Low from the headlight adapter pin triggers low relay and high from the high headlight adapter pin triggers high and low. Earth the relays and new headlight sockets and off you go. Because it triggers off the original headlight all of the dipping/hi on/high flash all still works
