i have a number of items that i'm looking to get rid of from an R33. Need to minimise my loses. Happy for local pick up or i can courier at purchasers cost. Negotiable on some items so just ask.
Located in Noosa on the sunshine coast (QLD)
PH: 0411967856
Items:
R33 Crank angle sensor - $75
R33 power steering pump - $140
R33 power steering resevoir - $50
R33 engine mounts X2 (good condition) - $60 each
R33 airflow meter - $120
R33 Climate control unit out of series 2- $100
R33 front door hinges X 4 & bonnet hinges X 2 - $20 the lot
R33 auto instrument cluster - 83XXX km on odometer - $90
R33 S1 type M RHS front bar grill piece - $15
R33 S1 type M RHS front bar indicator - $35
R33 heater core in heater unit - $80
R33 interior fan in housing - $40
R33 Aircon components - $175
R33 Auto tail shaft - front and rear - $50 for both
Charcol canister - $30
R33 Combination switch (wiper/indicator) - $40
R33 fan shroud - $50
R33 radiator with temp sender switch - $150
R33 brake master cylinder - $40
R33 brake power booster (S2) - $60
R33 windscreen washer bottle (washer motors not working) - $40
R33 front castor rods - pair (bushes in very good condition) - $50 each
R33 radiator over flow bottle - $40
R33 viscous fan (some small cracks in plastic) - $35
R33 RHS front lower control arm with balljoint - $80
R33 RHS front wheel bearing/hub/upper control arm assembly - $175
R33 LHS front wheel bearing/hub/upper control arm assembly - $175
R33 front brake calipers (not siezed) - to be sold as pair - $315
pictures in general classifieds
Edited by Riceburnerowner
Hi there,
How much do you want for the instrument cluster?
Does everything on it still work fine?
I am in melbourne how much will it cost for postage?
Thanks.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
