Make: Holden
Model: VX S Series II
Milage: 82,000
Transmission: Auto
Colour: White
Complied? YES
RWC supplied? YES
Currently registered? YES till August 08
Price: 13,000 or 12500 without RWC
Contact: 0401910780 or EMAIL: [email protected]
Comments / Modifications: 2.5" Catback Exhaust , Pacemaker Extractors , Lowerd on SSSL king springs and SSL Lovells, Stage 2 Shift kit, Yella Terra 1.97 High Ratio Roller Rockers || Great Condition, only minor scrape marks under front bar, Small dent the size of a 5 cent piece in passenger door and minor scratch on rear quater panel no longer then an inch. Interior is immaculate. Rims in pictures not offerd with the car. The car will be sold on 15" Interceptors. All reasonable offers will be considerd including trades.
Images:
Edited by jaysevu
https://www.sau.com.au/forums/topic/196049-holden-commodore-solddddddd/
Its a pity your not in NSW,
Thats the sort of car im after. I have a 96 Series 2 R33, 3" cat back (5Zigen?) exhaust, HKS pod. I imported it back in 03 through www.directimported.com.au
Its just hard to get the baby out of the back seat these days... So I have to sell my beast.
Cheers
Matt
Very frustrating isnt it Matt .. Just looking at potential cars to check out once the commo is sold, alot of nice ones interstate! .. gota weigh up whether or not its worth the travel i suppose!
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
