Make: Holden
Model: VX S Series II
Milage: 82,000
Transmission: Auto
Colour: White
Complied? YES
RWC supplied? YES
Currently registered? YES till August 08
Price: 13,000 or 12500 without RWC
Contact: 0401910780 or EMAIL: [email protected]
Comments / Modifications: 2.5" Catback Exhaust , Pacemaker Extractors , Lowerd on SSSL king springs and SSL Lovells, Stage 2 Shift kit, Yella Terra 1.97 High Ratio Roller Rockers || Great Condition, only minor scrape marks under front bar, Small dent the size of a 5 cent piece in passenger door and minor scratch on rear quater panel no longer then an inch. Interior is immaculate. Rims in pictures not offerd with the car. The car will be sold on 15" Interceptors. All reasonable offers will be considerd including trades.
Images:
Edited by jaysevu
https://www.sau.com.au/forums/topic/196049-holden-commodore-solddddddd/
Its a pity your not in NSW,
Thats the sort of car im after. I have a 96 Series 2 R33, 3" cat back (5Zigen?) exhaust, HKS pod. I imported it back in 03 through www.directimported.com.au
Its just hard to get the baby out of the back seat these days... So I have to sell my beast.
Cheers
Matt
Very frustrating isnt it Matt .. Just looking at potential cars to check out once the commo is sold, alot of nice ones interstate! .. gota weigh up whether or not its worth the travel i suppose!
    • Don't do it if your gearbox box has already having syncro issues. The short hifter will put a greater load on them. If you must I remember Nismo did a shorter shifter, with the top part being physically shorter and the part that went into the gearbox was the same as stock. In saying that I've had a C's short shifter (I think) in mine for many years, which was given to me as the previous owner was not sympathetic to the gearbox. Thus forwarned I was careful and had to modify my normal changing style. You have to be super accurate with your clutch and shifts
    • Well, after a week of daily driving and having to crawl out between the wheel and the side intrusion bars. I got myself a quick release setup. I went with an NRG short hub and Quick Release with some cute heart cutouts on the pull tabs. Nice and matchy matchy with the rest of the interior accents I have going on.  The only downside is the total stack height even with the short adapter is longer than the old HKB boss kit. Luckily I had some adjustment left on the column so move the wheel away.
    • stock shifter with new bushes, springs and cup will improve it. Gktech do all the bits. The opinion as the years have gone on is the redline is not great in old gearboxes.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
