hey guys,
I pulled into the petrol station today to fill up (after a 80k freeway drive, mostly doing 110kph), and was about to shut the engine off.
It suddenly started making a real loud knocking/banging noise, and idling rough. It sounds like the noise is coming from the top of the engine, but i can feel it through the clutch pedal.
The things ive checked so far are the oil and coolant, which are in perfect condition.
The spark plugs are in mint condition.
I had a look at the pistons with torch and they look excelent too
I pulled the cam cover off the intake side(which is where the noise sounds like its coming from) and everything looked to be in order.
the only mods i have are a pair of pods, and a cam gear. car is driven daily, but not thrashed daily (although it copped a fair bit saturday). Oil changed every 6000ish k's, and its always run on ultimate 98. Its never caused any problems in the 2 years ive had it.
When you crank the engine it doesnt make the noise, only when it fires up.
im thinking the timing belt has slipped a tooth, the cam gear has loosend, or there is some serious bottom end bearing damage.
I know its hard diagnose problems over the web, but any ideas would be great.
thanks heaps,
steve
Edited by PHATR32
Big guess to say it's slipped a tooth. How olds the belt in it?
I wouldnt think a big end knock (bearing issue) would cause it do idle funny...
Could be the other way around. If the cars missing (usual AFM, AAC etc) the piston can do funny things when it goes over TDC and doesn't fire. It can knock about... thats possibly what your hearing.
Sorry I'm no real help, just some thought :)
try and issolate a cylinder if possible. depends how harsh the noice is, wouldnt wana cause any more damge. however by issolating the cylinder your in the general direction. could be a collapsed lifter?
they actually have solid lifters and naturally have fairly loud heads.
My mates GTR had simular noise, sounded like it was in the top of the head etc etc etc, turned out to be a bottom end bearing spun. worst case scenario and for your sake i hope its not.
well i took off the cam cover from the other side (exhaust) and it looks fine, also the timing belt is fine and the markings are exact. the adjustable cam gear also hasnt moved from 0.
i turned the engine over a few times by hand and found it gets stuck when cylinders 3 and 4 are at TDC (or there abouts).
it will turn over bout 2 or 3 times and id feel slight hesiation (cyl 3 and 4 TDC) then on the next turn it would get stuck to the point where id have to give it a bit of force to keep it turning.
Ive checked the belt incase theres a rock or something in one of the teeth but i found nothing.
the tapping noise is REALLY loud btw, but i havnt reved it over 1k, only idled it for a few seconds.
steve
Im very new to skylines and this is probably wrong but thought i'd throw it out there for the hell of it
My brothers r32 (rb20) started making a really loud tapping/knocking noise a couple of days ago, would rise with revs and sounded like it was from one of the front cylinders. It actually turned out to be the clutch on the fan had given up and was making the racket. Its easy enough to test cause you can just slip the belt off and see if the noise goes.
My 2c worth
*Edit* After reading your latest post, probably not what im suggesting...
Edited by Scottydoo
lol, i got shit in my wallet......
when i push the clutch in it still makes the noise, that said, i could definetly feel the banging through the clutch.
although, the clutch wouldnt screw up exactly when pistons 3 and 4 are TDC.
i do all the work my self, of course if the engine requires rebuilding ill have to get a pro to do it as i dont want to risk screwing it up etc.
ill do a compression test tonight to see if itll show anything?
steve
Edited by PHATR32
hey guys,
i just ran a cold compression test and all cylinders were between 135psi - 140psi except for cylinder 3 which is at 45psi!
as mensioned above when i turned the crank by hand it would get stuck when cyls 3 and 4 would hit TDC.
so i pulled the cams off and took off the lifters on cylinder 3. it all looks ok, and the valves move in when i apply force. How can i tell if a valve guide has dropped?
im gonna have to pull the engine out either ways but would anyone have any idea on what could be causing the banging and low compression?
thanks guys,
steve
Edited by PHATR32
well, ive been pull the engine bay apart these past few afternoons, and found the pipe that controlls the wastegate actuators had come undone!!
weird thing is i hadnt noticed any increase in boost?? that said, i do have a stock exhaust.....
engine will be out and apart this weekend hopefully.......
i would put money on a spun big end bearing!
i know that sound well, sorry to hear that.
most the time when a big end bearing starts to go , it sounds like it's coming from the top.
russ
    • I mean it's probably likely that people overestimate their skills in dialling in a setup and noticing the changes. I had SK shocks and springs, and added heavier springs and got them revalved by Sydney Shocks to suit based upon what I told them I wanted the car to handle like. I got back a completely different feeling set of shocks, which probably (?) feel great on track but holy hell are they rough on tram tracks and the like. Truth be told I doubt I'd be any faster or slower with either setup, or camber/castor combination. I also had whiteline eccentric castor bushes up front of my R34. I removed them and put in poly non-adjustable ones to soothe my OCD (nobody ever set the castor the same side to side, and it'd be near impossible to do) and be happy the wheel is centered in the well now for clearance reasons. Yes I wanted it to move 1mm 'back' :p I've effectively set my castor back to stock, negating all the benefits of that which is supposedly massive. I can't tell any difference steering the car.
    • You reckon? I have to disagree. Notwithstanding that at some point we may all be forced to do this to our cars if we want to keep driving them, there is absolutely nothing about an electric-converted-previously-IC-car that is ever good. EVs that are built by OEMs on platforms that were originally IC already suck, let alone the shitty outcomes that result from doing it as a retro to something that was actually built as an IC car. This is because the platform really needs to be designed to house the battery in a useful place (ie, down as low as possible) and the motors are properly located relative to the wheels that they have to drive. Converted platforms already suck at this. But when you try to shove sufficient battery capacity into a previously IC car, you can't put it down on/in the floor, because that space doesn't exist. You can't find enough space where the fuel tank used to be (if it is an inboard fuel tank) and you don't want to hang it out behind the rear axle line if you had a rear fuel tank. And there's not enough space in the tunnel if you still want to use it for anything remotely like what it was originally used for. The engine bay is too big for a motor, and you'd really prefer that the motor for the rear wheels wasn't in the front engine bay anyway. And there's not enough room where the diff was for a proper man-sized E motor. And then.... there is the complete lack of soul and emotion that is provided by EVs. There are some cracking restomods out there. Like the Alfaholics GTA thingo. But it is petrol powered. Look at the alternative EV version of a GTA restomod by Totem. it is jaw droppingly beautiful. But by all reports is is objectively awful to drive, despite having 600 HP or something, simply because there is nothing there. It sounds like a sewing machine or a leaf blower. It should scream and wail and make the hairs on your neck stand up. Oh, and it's 1500 bloody kg in a car that was <900kg when new. GTRs are heavy enough as it is without pushing them up to 2tonnes worth of pork.
    • https://www.dezeen.com/2025/01/06/nissan-electric-r32-skyline-gt-r-godzilla-sports-car/   I reckon this is pretty cool. Lots of other Resto mods have turned to ev power.
    • hahaha @joshuaho96 the most action it gets is when I have to drive from West to SE VIC to meet the fam. Even then, it;s on highway cruising speeds
    • don't know anyone in this thread, but i just found it, read the entire thing in a few hours, realized greg is still posting progress, and just have to say, this is awesome. it looks awesome. 100% right about the Uras kit making it a pain to get on hoists...have the same kit on my 34 and it takes six 2x4s and race ramps to do it without taking parts off. this reminds me exactly of this thread. https://grassrootsmotorsports.com/forum/build-projects-and-project-cars/r63-amg-the-unicorn-of-my-destruction/110824/page8/
