hey guys
so i blew my turbo on my r33 at the start of last year and got it replaced with a stock r34 turbo and its been running fine ever since..
but now just after this weekend, wenever i accelerate and hit boost almost everytime i get this really really loud siren noise coming from my turbo.. and its not just a little whine or anything either.. its a massively loud siren like noise like ambo/police siren.. and people stared at me wen i was driving to work this morning thinking ive got some siren sound im playing on purpose or something.. lol
anyways i have no idea wtf is going on but my guess is ive probably f**ked my turbo again.. :(
oh and my cars pretty stock.. running stock psi.. no fmic etc..
any help appreciated
thanks
jenna
https://www.sau.com.au/forums/topic/196071-turbo-noise-on-my-r33/
I just blew my (stock) turbo (on stock boost) casually driving home at normals revs and speed. I limped it to my mechanic, and when the heard the "whizzing" noise mine made when I revved it, he instantly said the turbo is dead.
Hope you have some savings!
thanksss for the replies :D
so i got it towed and its going into the mechanics later this week.. doubt its completely dead but it may be on its way out.. anyway good chance to upgrade which i was planning on doing soon.. hopefully something can bolt straight on.. hmmm about that.. anyone know what turbo does? does a t28?
Edited by NiSmO`ChiCk
My friend had this (siren noise) happen to his R33 Series 2 turbo. We're pretty sure that it was a bent shaft at the compressor end and the Nylon comp wheel hitting the housing.
Time for another turbo :P
I think the fins are chipped or cracked in your turbo... if this goes, you have no choice but to replace it... damn, a mate had a similiar problem... it's more like a high pitch tone then anything else.
I got the same sound when i installed my 2535 a year ago...siren sound was loud as!! i checked and rechecked everything on the intake side of the engine and all was good...funnily enough...the sound went away when i got a resonator welded onto the exhaust...this was done for a differenct reason but it stopped the wailing...so for me it was probably some sort of resonance through the pipes...and it wasn't the turbo dying...its run 1.2-1.3 bar for a year since then and its still ok...
Take what you will from my experience...i'm not saying its definitely the cause but it was for me...
Edited by limpus
Had this happen to me, a bit of the exhaust wheel chipped/came off and unbalanced the shaft, so was the lovely sound of the bearings eating themselves :P, i didnt want to accerlerate anywhere, so embarassing. Lucky i had already bought a GCG R34 highflow for $2k off the SAU forums :D, it even came with braided lines plus all the other bits.
cheers
Evil
Ive had the siren sound for a year now on a hks turbo.... had it rebuilt twice cos i though it was broke but its still there.... it went away briefly with a new higher HP tuned eprom (the turbo induction sound went really quiet and the siren sound dissapeared but the car went way harder)
then the siren came back after i did an engine swap (done to fix engine oil leaks) which also brought ping ping caused by timing issues at higher boost....
EMS now installed and getting tuned on wed so if the siren goes away im gonna put it down to engine specific timing setup in conjuction with afr's somehow.
I wouldnt worry unless there is shaft play or blades touching the housing......
the siren sound is much different to the grinding sound of blade on housing
Limpus: some of the 25 series HKS turbos like to make funny siren noises, its jus the way they spool.
Spunky monkey: I've had the mosquito whine from a turbo but i've also had this full on siren noise. It has to be heard to be believed....very freaky stuff haha.
Yeah...i put it down to some weird resonance through the pipes or something like that as it only happened after i put in the original HKS dump pipe...then at a later date i get a resonator welded onto the catback and then the noise went away...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
