hey guys
so i blew my turbo on my r33 at the start of last year and got it replaced with a stock r34 turbo and its been running fine ever since..
but now just after this weekend, wenever i accelerate and hit boost almost everytime i get this really really loud siren noise coming from my turbo.. and its not just a little whine or anything either.. its a massively loud siren like noise like ambo/police siren.. and people stared at me wen i was driving to work this morning thinking ive got some siren sound im playing on purpose or something.. lol
anyways i have no idea wtf is going on but my guess is ive probably f**ked my turbo again.. :(
oh and my cars pretty stock.. running stock psi.. no fmic etc..
any help appreciated
thanks
jenna
https://www.sau.com.au/forums/topic/196071-turbo-noise-on-my-r33/
I just blew my (stock) turbo (on stock boost) casually driving home at normals revs and speed. I limped it to my mechanic, and when the heard the "whizzing" noise mine made when I revved it, he instantly said the turbo is dead.
Hope you have some savings!
thanksss for the replies :D
so i got it towed and its going into the mechanics later this week.. doubt its completely dead but it may be on its way out.. anyway good chance to upgrade which i was planning on doing soon.. hopefully something can bolt straight on.. hmmm about that.. anyone know what turbo does? does a t28?
Edited by NiSmO`ChiCk
My friend had this (siren noise) happen to his R33 Series 2 turbo. We're pretty sure that it was a bent shaft at the compressor end and the Nylon comp wheel hitting the housing.
Time for another turbo :P
I think the fins are chipped or cracked in your turbo... if this goes, you have no choice but to replace it... damn, a mate had a similiar problem... it's more like a high pitch tone then anything else.
I got the same sound when i installed my 2535 a year ago...siren sound was loud as!! i checked and rechecked everything on the intake side of the engine and all was good...funnily enough...the sound went away when i got a resonator welded onto the exhaust...this was done for a differenct reason but it stopped the wailing...so for me it was probably some sort of resonance through the pipes...and it wasn't the turbo dying...its run 1.2-1.3 bar for a year since then and its still ok...
Take what you will from my experience...i'm not saying its definitely the cause but it was for me...
Edited by limpus
Had this happen to me, a bit of the exhaust wheel chipped/came off and unbalanced the shaft, so was the lovely sound of the bearings eating themselves :P, i didnt want to accerlerate anywhere, so embarassing. Lucky i had already bought a GCG R34 highflow for $2k off the SAU forums :D, it even came with braided lines plus all the other bits.
cheers
Evil
Ive had the siren sound for a year now on a hks turbo.... had it rebuilt twice cos i though it was broke but its still there.... it went away briefly with a new higher HP tuned eprom (the turbo induction sound went really quiet and the siren sound dissapeared but the car went way harder)
then the siren came back after i did an engine swap (done to fix engine oil leaks) which also brought ping ping caused by timing issues at higher boost....
EMS now installed and getting tuned on wed so if the siren goes away im gonna put it down to engine specific timing setup in conjuction with afr's somehow.
I wouldnt worry unless there is shaft play or blades touching the housing......
the siren sound is much different to the grinding sound of blade on housing
Limpus: some of the 25 series HKS turbos like to make funny siren noises, its jus the way they spool.
Spunky monkey: I've had the mosquito whine from a turbo but i've also had this full on siren noise. It has to be heard to be believed....very freaky stuff haha.
Yeah...i put it down to some weird resonance through the pipes or something like that as it only happened after i put in the original HKS dump pipe...then at a later date i get a resonator welded onto the catback and then the noise went away...
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
