Sorry to hear about everyones dramas....I was at work in the city and it really didn't seem to rain THAT hard.
Always a good idea, esp if you have a house at the bottom of a slope, to routinely clean out your drainage around your property as usually the only time you find out they are blocked is when it floods!
https://www.sau.com.au/forums/topic/196099-flooded/page/2/#findComment-3512071
as long as everybody's 32's are safe & dry, then i can sleep easy :whistling:
yeah the whales love the water... they'll be fine... but the 32's... won't someone think of the 32's?
our house was on the top of the slope, so we were fine, but the house at the end of our street copped a small flooding.
https://www.sau.com.au/forums/topic/196099-flooded/page/2/#findComment-3512084
    • It's more like on average the things I see a lot of things going wrong. Yes, usually the people who reach out are the ones who are having problems but on average it feels like mechanics and tuners here aren't really competent. I swing between thinking my standards are just way too high and wondering whether people really are just this dumb. I just had the strangest 10+ reply argument on a Facebook group over someone insisting that the factory R34 GTT boost control solenoid reduces boost pressure to 5 psi when it's on and raises boost pressure to 7 psi when it's off despite showing the exact plumbing in the factory service manual and the solenoid behavior detailed in the FSM.
    • I steam cleaned my near new set of volk gtc wheels 14 years ago and farrkkked them lol. The clear coat cracked like spider webbing in several areas. Lesson learnt don't do that. ๐Ÿ˜ญ
    • If you don't touch the CAS, then you're fine.
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.ย  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.ย  If you hold the wand any more than 45 cms away from pretty muchย anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.ย  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.ย  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
ร—
ร—
