I Found A Turtle In My Backyard Wtf!
Id adopt him, Ive wanted a turtle for ages. They are cool as, but kind of high maintenance :rofl:
Compared to other pet's they are pretty low maintenance. Long as less you do 1/3 tank water changed once every 2-3wks, have a decent filter & tank set up, they're pretty much otherwise maintenance free. Food wise u just have to mix up their food, so everything from live fish, worms, crickets, etc ... to the frozen meat squares u can buy, and feed them every day or every second. Only other thing u really ned to do is let them out of the tank every so often for a walk around your back yard in the sun. 30mins on a nice day is all they need ;)
Live fish is good entertainment too ... watching them stalk & catch them. :D
I've had turtles for years ... more interesting than fish (IMO).
i'm 99% positive a person has to apply for a reptile license to own a turtoise.
Correct ... every other turtle/tortoise breed except the Eastern Long neck requires a licence to own & keep.
The turtle found is a Eastern Long Neck, so can be kept by anyone as long as less shell length is over 12cm ... otherwise u require a licence.
Edited by -FUZZY-
  • Replies 42
Posted Images
Compared to other pet's they are pretty low maintenance. Long as less you do 1/3 tank water changed once every 2-3wks, have a decent filter & tank set up, they're pretty much otherwise maintenance free. Food wise u just have to mix up their food, so everything from live fish, worms, crickets, etc ... to the frozen meat squares u can buy, and feed them every day or every second. Only other thing u really ned to do is let them out of the tank every so often for a walk around your back yard in the sun. 30mins on a nice day is all they need :rofl:
Live fish is good entertainment too ... watching them stalk & catch them. ;)
How about those turtles with the red spots on the side of the head? I always thought they were illegal in Australia, but I've seen them for sale.
yeah you need a licence to own them.
pretty easy to obtain and doesn't cost too much. I had one for a while when l had some short head turtles .... but now onlyhave eastern long necks so don't need to worry.
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
