The people running the dyno were a joke, one guy could not even drive the JMS 33 onto the dyno. Took them ages to set up the cars and then had problems, better than nothing i suppose.
Anyone know what numbers the cars made, it seemed to reed very different to the normal Dyno Dynamics, the 33 made 257 and they were going again but i gave up waiting.
Yes we also thought they took too long to get the Cars on the Dyno. I think it was just the Dyno, not as easy to set up as others. They People doing it were top Guys very friendly. We had a lot of trouble running the Skyline because the RX-7 before had Silicon on his Tyres which covered the Dyno Rollers. Our first run was 174rwkw's?? Couldnt stop the wheel spin until we pilled a whole heap of Guys in the back and left the tie downs loose to the Car would ride up ontop of the roller. Finnal power was 448kw but the computer corrects it to 434kw's with still some wheelspin up top.
Dyno graph and pics here
http://www.japanesemotorsport.com.au/autosalon2003.htm
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
    • Sounds like the oil pressure light is wired into the oil temp sensor... As it warms up, resistance on temp sensor reduces, hence more current can flow and the dash light gets brighter.
    • Got the front subframe and suspension in.
    • If it's cold in summer, then no issue. If it's cutting out every few seconds and you're not reaching your target temp, then there's an issue. One could be the pressure switch and the other issue could be the temp probe inside the evaporator.
