Had the car on dyno the other day and my sard 800cc twin spray injectors are getting to 95% duty cycle running 575rwhp
Have a sard rail, sard reg and 044 mounted in tank...
From what I have been told the 044 is probably running outta flow, hense the high injector duty cylce. I have not checked the fuel pressure since we set it with standard fuel pump in but I'm going to assume its still at 3bar.
2 questions!
Would it be worth bumping up the fuel pressure to say 3.5/4bar to get a bit more injector clearance or will this cause issues?
And what thread do i need for the Sard FPR to put a gauge on, is it 1/8 NPT?
Cheers
Simon
https://www.sau.com.au/forums/topic/196162-some-fuel-issues/
400rwkw is the limit usually found with a single 044 pump.
you could bump the pressure a bit, but remember whatever boost you run that pressure adds to your base fuel pressure. i.e 50psi base and 30psi boost = 80psi fuel pressure.
i would look at twin pumps myself, if your going for more power, or up the pressure a little to see if its possible to lower the duty cycle a bit if you are happy as it is.
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
