cant help u with a guide but mate of mine has done it, pretty basic stuff. from memory the dash surround (round the cd player air con etc) was just held in by clips. theres a screw behind the ashtray, and you unscrew the gearknob the pull the bit around it straight up, think theree MIGHT be a couple of screws holdin this down (might need dash surround out first to allow you to pull it up)
the actal dash itself is a lil bit complicated to get out, cant remember where the screws etc are, but drop your steering wheel right down and sorta flip it forward towards you, although you dont need to pull it right out to get at the LED's
sorry cant be of too much help, but its better than nothing. mate did it following a guide also, i'll try and get him to link it
Im assuming that you wanted to change the instrument cluster lights. Very simple job and it will only take around 20min. It involves taking off your whole instrument cluster to do so. Also taking off your steering wheel as well.
1) Take off the steering wheel
2) There should be a screw on top of the dashboard. Undo that and there should be 2 clips at the bottom. Take that whole piece off.
3) The instrument cluster is now exposed. There should be a screw on top and 2 on the bottom. Undo those and carefully take off the whole instrument cluster piece.
4) At the back there should be 3 harnesses plugged in. Undo those and take it out.
5) Flip the cluster around, and you should see plastic sockets sticking out. These contain the light bulbs. Change it and put it all back together.
and there your cluster will have a new colour...
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
    • I have information on this for anyone that comes looking again. https://www.facebook.com/share/p/18gsbFaYTU/ The rb25det neo from the stagea has the same sumo as rb26 and r32 gts4 (and other awd models). The sump that has caused so many problems during swaps are from the awd neo Gloria's. The casting numbers on the block and oil pans are different so this may help identify if you can't confirm where the motor came from
    • Not feasible to fix the boot lid you had? Damage looked minor/hard to even see :p Source: Drove into something recently and you should be happy you didn't!
    • Another new used boot arrived at the painters, it was sent back as there was nearly as much damage as the original one I want to replace  Finding a clean used boot lid is proving problematic, and I'm not keen on dropping $1500 on a new one from Mazda Sigh....
