I'm thinking you'd have to loosen it. If there's too much tension, when on light load, there won't be enough positive pressure to open the valve, and the air will simply keep moving on into the compressor housing and get chopped by the compressor wheel, thus the fluttering sound. If you've bought it new, the manual ought to state which way you should turn the screw to loosen the spring tension.
Nick
