im jumping on the 34 with loud induction noise bandwagon. i spool like a bitch
K&N pod
That's funny... then wtf, does my friends R34 sound like it's got no suction .. he's got a power FC - could it be this??
A computer isnt going to determine how loud your spooling is. Its got to do with A) the type of filter you have B) how much boost you are running. Also i noticed with mine it increased by putting on a front mount. If your talking about fluttering then you Bov will come into it depending on how tight you have the srew wound.
not just the difference in the turbos? dude i no has rb25 turbo on his rb20 hr31 and made very different induction sound. very similer 2 my mates stockish r33 (no pod).
dont mean that induction sound? but yea just throwin idea round...
Edited by OUTATIME
I think I'll have to clarify slightly... R32s / R34s do have suction sounds... but much much smaller... perhaps this is a feature in R34's to make it more quieter an hence more cruisey... I don't know... but R33's have the Loudest suction sounds... love it or hate it... this is the truth...
haha ok. we believe you ;)
seriousy, like 90% of everyones posts, its got to do with what type of pod. exposed/in a box. and how much boost.
wen my r33 had just a panal filter k&n, the induction noise was high pitched @ 12psi
then when i put the aluminum pod on, i got a louder deeper induction sound. sounds like the engine wants to suck in seagals haha.
Ha ha ha :D
I just got my stock BOV put be on... and guess what? The induction sounds different now...
my rb20det had gcg highflow turbo, 3" turbo back, HKS Mushroom pod, and no induction noise.
I just put on Front mount, hks ssqv and a plazmaman forward facing plenum, and now even on idle u can hear the bastard sucking air in from outside car with bonnet shut.
ATM getting a 4" intake pipe from stainless... should sound sick mate.
Man my car has the stock box (33)... People have said it sounds like a fugging jet following them!
And I have been in a few 32s/34s... way way less suction noise with pods...
For being nearly stock, my car is a freak!
Thank you.... this is exactly what I am trying to say!!!
on my old r33 gtst, i had a fair few mods, bigger turbo, injectors, fuel pump, power fc, turbo back exhaust, fmic, bov, pod and now i have an r34 with just a fmic, and pod filter. and the r34 has a louder induction sound, but the spooling on the r33 was alot louder, if that makes sense :S
Wonder why? I suppose the intention of this thread was to ask everyone (mechanically) why this is the case? :(
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
    • Did some FASTing ...got the impression that the actual part# was a moot point ; seems all of these hardlines for coolant are discontinued/NLA... like, I take it you're after the hardline that bolts onto to the manifold...that's NLA according to amayama & nengun .... ...just to clear up some confusion, they typically mounted the AAC valve to the intake manifold somewhere near a coolant passage, so the body of the valve heats up & holds it open when engine's up to temp - no coolant flows through the valve, it's a mechanical, thermal connection.
