Hi all,
Just want to know if anyone has used the forward facing plenums off ebay and what the quality is like?
Also was there many mods to get them to fit?
Would it be better to go say a plazman or a RIPS one from new zealand?post-42704-1196716965_thumb.jpg
That what they look like if your not sure what i mean any info would be great.
Thanks Guys and Girls
https://www.sau.com.au/forums/topic/196219-r32-gtst-intake-plenum/
i have personally talked to the people on ebay selling this one he said the only modification is you have to bed the water pipe and showed me where on a pic. then about a week later he is selling the plenums with the modified water pipes. i currently dont have the money to shell out for one of these. a buddy of mine bought one of the jun ripoff ones from ebay not from pnt_performance and he said it costed another 1200 to have a shop modify it to make it work. its up to you if you wanna try it. i would personally buy from pnt_performance when im ready to purchase my manifold tho. unless the ausies have some proven aftermarket ones that are redily availiable and they know from expierience they are good.
Unless your planning on making 300rwkw from your RB20 then a front facing plenum provides no gains.
I mean it does give you minimal if any top end... But it has been proven time and time again that a front facing plenum on an RB20 actually hinders the response/what little low down the car has.
IMO your money could be spent else where.
Thanks guys,
I will be aiming for 300at the treads i did a head gasket in it and im pulling the engine out and giving her some forgies ive got a bigger hyper gear turbo for her and some nismo injectors and going to put tomei cams in it.
The main reason i want to get rid of the cross over is the space issue it looks neater and the pipes dont pass the engine twice the less pipe and bends the better.
I reckon the "power gains" are all ass dribble too, I just loved the bling factor and I wanted short ass intercooler piping and what not.
I can change injectors with ease now (not that I plan to change them often), and spark plugs don't require me to move intercooler piping, bov etc. Last but not least it looks the business.
Call it wank factor, Call it what you want. At the end of the day each to their own :cheers:
At least its not a claim from WA....where they get 220rwkw out of stock RB20DET injectors, and 200rwkw out of stock silvertop RB20DET turbos....
I was making 205rwks from stock injectors and AFM and you only have to read through a few threads here with people pushing 200+ from stock injectors.
Sure its not healthy hence me going 550's and a Z32 with the new set up ;)
Dont waste your time and money on a forward facing plenum if you ask me, there are 1000000 of people running the stock plenum with big numbers and no problems with clearance issues.
If you are going to run one then do yourself a favour and talk to Kemp :rofl:
Ku Engineering (Very similar to the one you have pictured)
and yes the bottom metal hose needs cutting and welding, I learnt that the hard way :rofl:
haha it lives, does it make noise yet..... stop posting and make noise.
LOL....Just gotta finish the cooler piping (waiting on my stainless pipes) then its time to wire the E-Manage and start the bugger (I dont think the std computer will like the Z32 AFM and 550cc injectors too much) :P
i personally wouldnt be looking at a plenum i would be looking for a different engine
any turbo u put on a RB20 to try and make 300kw is going to be laggy as hell
ive got a 2L sr20 making over 300kw and it still spools up faster then any RB20 making near 300kw
legend01 makes 301kw atw from memory using a GT3040 and stock cross over pipe
then again it is a rb21.
im using a custom top half (not a cut and shut) with stock runners.
1st off though buy a garrett or trust turbo, rather than spending the money on a fancy plenum.
    • Yeah, you are right. It seems easier and more reasonable to boost the engine. And as you said the blocks are very similar but the cylinder bores are different.
    • Sound logic, but in actuality way more illegal than just having the wrong pipe. Normally, doing something like that would be forgery. Meaning you may have certain documentation for vehicle parts, but the actual parts are different ones and you just assign them the numbers and badging from the documents. But nevermind that. Nonetheless, I AM curious if this pipe was ever made by any official manufacturer this way, because I honestly am not familiar with this pipe layout and shape. As I will be putting on the HKS Silent Hi Power once my exhaust gaskets arrive, as long as it sounds right I will just roll with this front pipe. I can always order the actual Mines part if I run into legal issues. It would be an unnecessary expense as there is lots of other problems I have on this car as of now.
    • So, weld a plate with the Mines logo laser cut into it, onto it. Instant Mines pipes, whether they were or weren't originally.
    • I don't know if the blocks are "the same". They will be very very similar. Obviously, either the bore or the stroke is going to be bigger on the 20. If the bore is bigger, then the 18 head is unlikely to fit properly. If the bore is the same, then you can almost certainly fit the CA18 head, but there migth be a few fun things you have to do to make water galleries (or other things) line up properly. Or... it could just be real easy. Is it worth the effort? Almost certainly not. You can make nearly as much power on a 2 valv ehead as you can on a 4 valve. There's not any "magic" in a 4 valve head.
    • Yes, me too!!!!  I need to find a something that has all the abbreviations for what these cars have LOL
