  • Replies 41
Posted Images
would it be worth getting a powerfc without the controller?
yeah, the hand controller tends to be more of a visual aid then anything. Most tuners just plug in a laptop to tune the powerfc than use the handcontroller. Personally i would spend the extra 200 on the controller, but thats just me cause i like to fiddle with things haha.
https://www.sau.com.au/forums/topic/196231-first-dyno-run/#findComment-3512210
the tuner said it's running rich and a few more psi would help that alot,i have a manual boost controller here would it be worth putting that on?
Edited by mjones
https://www.sau.com.au/forums/topic/196231-first-dyno-run/#findComment-3512216
thats abit scary... whos your tuner?
you'll notice an increase if you bump up the boost, and its probably the best bang for your buck mod you can do. Although thats not going to help with your afr, the ecu is already running rich and its going to continue overcompensating fuel, ie running rich. The only thing to help you with that is a piggyback like a safc, or a new ecu like powerfc.
https://www.sau.com.au/forums/topic/196231-first-dyno-run/#findComment-3513095
it's not my tuner it was just the guy at carline,which safc would u recomend?
https://www.sau.com.au/forums/topic/196231-first-dyno-run/#findComment-3513174
how far are you wanting to go with you car?
how much power do you want?
what are you using it for?
this will determine what is going to be the best option as terms with cost efficiency for future modifications and your car running at its optimum level.
I remember, i started with a 121rwkw with an auto. Its now manual and will have 300rwkw when it goes on the dyno again.
https://www.sau.com.au/forums/topic/196231-first-dyno-run/#findComment-3513216
see what i mean man, if u compare your graph to mine, s1.5 r33t, with fmic and exhaust.
U ARE DOING PRETTY WELL!!!
*P.S just to add a tag on here man. i have adjusted my fuel prs, now it runs crazily rich and on 8psi. so could i run 12-14psi well?, i used to hit a brick wall/flat spot at 12psi
Edited by r33cruiser
https://www.sau.com.au/forums/topic/196231-first-dyno-run/#findComment-3513234
is that with the standard ecu?if it is how come it dips like that mate?
https://www.sau.com.au/forums/topic/196231-first-dyno-run/#findComment-3513243
yer stock ecu
3" exhaust
monkey warehouse fmic kit
fpr
bosch 040
boost controller on 8psi
pod with shield
nfi why it does that hey. it was my first dyno on a dyno day.
but at time of dyno i had an 02 sensor that was on the way out, and plugs over 1yr old
i think that may be the reason
but changed that now
https://www.sau.com.au/forums/topic/196231-first-dyno-run/#findComment-3513255
this would be my path i would take if you plan to have 200rwkw.
aftermarket ecu. Power fc are one of the most reputable ecus around.
some people have made it to 200rwkw on the standard turbo, but with being a bush bearing with ceramic wheel i wouldn't risk it.
limit on the standard turbo is about 12psi.
Also i would consider updating your injectors as they will get close to running on max duty cycle and also your air flow metre
Turbo- pretty much the best option and to retain standard manifold and not resorting to an externally wastegated turbo would be a GCG highflow turbo being ball bearing and having steel wheels, you can push the boost up to a greater limit then ya standard turbo and will easily hit 200rwkw.
GCG highflows are capable of seeing 260rwkw.
So my opinion if i was in your shoes i would look into
ECU
Split dump - less restriction
injectors
AFM
Highflow turbo
And then possibly blow off valve for better control and no leak.
there you will have 200rwkw and also and then some if you wanted.
Edited by bazr33
https://www.sau.com.au/forums/topic/196231-first-dyno-run/#findComment-3513292
    • I see... Any idea how much fab work is required? I note the Hygear megathread but its like 900 pages
    • I should try the experiment you're talking about, the throttle switch is still there carried over from the R32 and it's still all wired up but after I did the whole intake manifold refurb and had to recalibrate the TPS I managed to somehow get the idle switch reporting activation at 0.22V, then when I adjusted it to 0.45V for idle it decided the engine was permanently no longer idling which caused some very weird behavior, closed loop idle was disabled so it would basically be at the whims of the cold start valve and whatever the base timing table was at. Then just unplugging/replugging the TPS with the ECU live caused it to relearn the idle TPS position and decide 0.45V was idle. Presumably there's nothing in the TPS that allows for the throttle switch to "recalibrate" like that, not easily at least.
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
