this would be my path i would take if you plan to have 200rwkw.
aftermarket ecu. Power fc are one of the most reputable ecus around.
some people have made it to 200rwkw on the standard turbo, but with being a bush bearing with ceramic wheel i wouldn't risk it.
limit on the standard turbo is about 12psi.
Also i would consider updating your injectors as they will get close to running on max duty cycle and also your air flow metre
Turbo- pretty much the best option and to retain standard manifold and not resorting to an externally wastegated turbo would be a GCG highflow turbo being ball bearing and having steel wheels, you can push the boost up to a greater limit then ya standard turbo and will easily hit 200rwkw.
GCG highflows are capable of seeing 260rwkw.
So my opinion if i was in your shoes i would look into
ECU
Split dump - less restriction
injectors
AFM
Highflow turbo
And then possibly blow off valve for better control and no leak.
there you will have 200rwkw and also and then some if you wanted.
sweet, cheers mate that helps me out so much!could i get away with using the neo safc instead on the ecu?
  • Replies 41
Posted Images
sup guys have another question. u can see on my graph on previous posts that my car runs really rich. runs a 10:1. RICH.
it was on 10psi. so wondering if i boosted it up to 14psi, would this help lean it out a bit.
cheers.
btw, stock ecu and mgt
cheers.
i think u'll need a new turbo if u wonna run 14psi as the stock one will crumble. :P
AiF
ECU
injectors
AFM
Highflow turbo
I have higlighted the parts of this post which are utter rubbish.
turbo is ball bearing.
limit of the turbo is not calculated on a "boost" number.
injectors and afm is not out of their range before the turbo is so 200rwkw is within their reach without maxing out either.
Hilfow turbo is not required for a safe 200rwkw
Stock BOV is perfectly fine for alot more power than the stock or hiflow turbo can flow.
cheers.
No. increasing the boost on a skyline makes the tune go even richer.
In R33 skylines, you won't be able to run much more than 10 psi without running in to R&R issues... (which will feel like a boost cut.. or you'll get misfire issues around 4500rpm .. plenty of threads on this issue)
the dip in some peoples dyno graphs on R33 skylines is very common with stock ECU..
search for that to find more details.
i was just going on what happened to me
my airflow metre was close maxing out at 220rwkw which isnt too far away from 200rwkw
and my injectors wer close to 90% duty cycle.
even my 555cc injectors are at 60% when on 240rwkw
Also was going from what other people have stated with the standard turbo that 12 psi was a safe limit on them
but hey whack it up to 18psi and see how it goes, i have never tried it, and never will.
And my utterly rubbish that i posted, was my opinion, people can take it onboard or have the choice of not to.
You didn't mention the words "IMO or in my opinion" anywhere in your post.
you posted "facts" according to you.
200rwkw to 220rwkw is a big difference.
stock injectors = 370cc
Calculation is
(injector size(cc) / 10.6) x 2 = horsepower per injector
convert to kilowatts: divide by 1.34
multiply by number of injectors
(370/10.6) x 2 = 69.8
69.8/1.34 = 52
52 x 6 = 312kw
lose 40-50kw to the wheels = 260 - 270rwkw at 100% duty cycle.
take 20% off for good measure
218rwkw @ 80% duty cycle
your injectors using the above and your said 60%
= 230 - 240rwkw (using 40-50kw loss to the wheels.)
Edited by GTST
So much hearsay and conjecture. IMO don't upgrade until you max it out.
For instance, my RB30 instantly maxxed out the RB20 afm and constantly ran in R&R as soon as it saw any boost with more than 10% throttle or over 3000rpm. Maxxed out at 183rwkw.. also, the exhaust side of the 25 turbo maxxed out (can't physically flow the exhaust gasses coming out of the 30). Have since had the stock ecu remapped along with 550cc injectors and a z32 afm installed.. still have to live with the turbo falling over about 5800rpm till after xmas :P
Do the upgrades slowly, as and when you need them - this will also help if you come across any issues (too many changes at once makes it harder to diagnose problems).
The only thing I suggest going full hog on straight away is, if you know you're going to end up with a bigass turbo, bigger injectors, afm etc down the track, then don't waste money on a simple piggy back to start with. Just get a full ecu and go from there.
Edited by bubba
For instance, my RB30 instantly maxxed out the RB20 afm and constantly ran in R&R as soon as it saw any boost with more than 10% throttle or over 3000rpm. Maxxed out at 183rwkw.. also, the exhaust side of the 25 turbo maxxed out (can't physically flow the exhaust gasses coming out of the 30). Have since had the stock ecu remapped along with 550cc injectors and a z32 afm installed.. still have to live with the turbo falling over about 5800rpm till after xmas ;)
If i changed the ecu to say a powerfc would the car still run with the right emissions?
  • 3 weeks later...
your running stock everything basically, why spend money on an emanage when you could use any old manual bleed valve to do the same thing... geez your only gonna run 12psi max and even then your still runnin stock ecu...
listen to GTST & bubba... lots of others on this forum will tell you the same... the ones that don't simply don't have experience or have been misinformed...
200rwkw should be almost achievable if you get zorst air intake a PFC and get a good tune, and take care of you vehicle...
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Gotta admit, I love the 20b Cosmo.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
