Hey guys and gals.......
i just bought my new r34 4 door its running a r33 series 2 engine and drivetrain and mechanical lsd
I have got a t04z with a .7 housing on it and reall just upgrade every thing from ignition microtect lt10 computer fuel pumps injectors and a list of other stuff the only internal is a better head gasket........
wat would be the next thing to do im pushing 310kw at the rears on 17.1psi on a cold night at the dyno on 98 octane fuel. boost comes on around about 4 grand some people hate the lag but i just love how angry it is to drive:)
i was thinking maybe cams any help would be great
thanks
Edited by Camo34
https://www.sau.com.au/forums/topic/196236-wat-next/
t04z and only running 17psi??? they dont come into there efficacy rating to about 24psi and over you could make more power with better response with a smaller turbo.... lol.
Yes go some cams, front facing plenum, and FORGIES. You should be able to make a lot more just by winding the boost up more.
Is it school holidays yet???
https://www.sau.com.au/forums/topic/196236-wat-next/#findComment-3512901
lol settle guys, this guy is legit and is in my town.
Thats a bit strange though, only 310rwkw at 17psi on a TO4Z, which is capable of much more.
I run 314rwkw at 19psi, on a GT3076 - which makes almost the same curve as a 300rwkw NA V8 here, and plenty of torque (700nm at 3200rpm all the way to the limiter)
And why is there a R33 RB25 and drivetrain in there? There is nothing wrong with the Neo engine - The neo engines are actually better because they come equipped with GTR Rods, which are much bigger than the standard RB25 rods. So they are much stonger.
https://www.sau.com.au/forums/topic/196236-wat-next/#findComment-3513055
curently i have
RB25DET 5 speed manual R33 motor and drivetrain motor has done 90 000kms
FMIC with custom stainless steel piping
GARRETT T04Z turbo with .7ar rear
custom stainless steel high mount manifold
TURBOSMART 38mm ultragate external gate
SPLITFIRE coil packs
MICROTECH LT10 engine management with 3 bar map sensor
EXEDY 5 puk sprung centre ceramic clutch
full custom stainless steel 3" exhaust + stainless steel screamer
custom stainless steel intake pipe
SARD 550cc injectors with collars
GREDDY type RS bov
MALPASSI rising rate adjsutable fuel pressure regulator
WALBRO hi flow fuel pump
GATES racing timing belt and water pump
BOOST FX short shifter GREDDY PROFEC E01 electronic bosot controller with LCD display
big brake upgrade with braided lines
GAB coilovers
rear camber arms
B&M oil filter relocation kit and 19row oil cooler
So your saying i should just go cams cam gear and wind the boost up ?
any idea wat stanard internal can take at all ?
Edited by Camo34
https://www.sau.com.au/forums/topic/196236-wat-next/#findComment-3513287
yeh you realise that by simply bolting all your stuff up to a rb26 that your still in the same boat you are now, if anything the older 26 will have a higher chance of failure.
or was 8500 for a built 26? doubt it.
just rebuild the 25 with quality parts and get a decent intake plennum on it.
Edited by James_03
https://www.sau.com.au/forums/topic/196236-wat-next/#findComment-3513875
sweet best place in brissy to get work done for a rebuilt rb25 is?
Most the placest in good old mackay just wanna screew more boost in to the stock engine and are telling me that it will be fine for years to come o.0
No offence to any tuners that read this that are from mackay.....
https://www.sau.com.au/forums/topic/196236-wat-next/#findComment-3514457
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
