My R33 is getting terrible fuel economy of 190-250 with 50 city trafic 50% freeway (190 driving normal, 250 driving miss daisy the whole time), and its really starting to give me the shits. Car has usual 200rwkw mods runing a PFC tuned by RE Customs
What I have done so far:
Made sure it was not my driving
Checked accuracy of fuel guage and speedo
Replaced 02 sensor
Cleaned AAC valve
Cleaned AFM
Got RE Customs to make sure the tune was spot on, they said it is now perfect, they checked for fuel leaks and found none, they said it would not be the cat because car is not down on power at all and drives very well.
The only suggestion the had was an injector(s) could be leaking (they noted the idle is somewhat rough) and this could be causing the problem.
So does anyone have any suggestions as to what else might be causing this problem before i spend the time and money getting the injectors checked.
Cheers
  • Replies 59
try replacing the fuel filter aswell, i replaced different items every few thousand kms and noticed an increase in kms from a tank each time, now im getting between 600-700km (highway) consistently from a tank (mine is stock standard though). I replaced fuel filter, O2, air filter, cat (and exhaust), spark plugs and went from 350 to where i am now (600-700)
^^^ WTF would you do that for? Any problems that caused you to do those two things?
190-250 is terrible dude, bloody terrible. I have this feeling the problem will be a leaking injector, but to replace with stock seems like such a waste of $. and I dont have the cash for some 750cc's and a retune just at the moment.
Edited by stolen_s15
get the injectors ultrasonically cleaned would be my next move. I had mine done by a mobile injector cleaner goy, came around, took about 2 hours.
Edited by chook
I like that idea.
What was the cost mate? Do you know if they are able to give you a report on the flow of the injectors?
Cheers
*EDIT*
Seems that around $30 per injector on site is the going rate.
As above, could be a faulty coolant temp sensor (tells the ecu to run rich until the car is warm)
Another possibly is check your brake drag (jack car up and spin wheels freely). Handbrake might of dropped a spring or maybe even ceased a caliper piston??? Both happened to my VL :P
Edited by Jmaac
Had same prob with my R33 GTST and turned out to be O2 sensor. Heres a couple more ideas:
Pull the spark plugs out.
If its running really rich they will look like they are really black and very sooty.
If they are ALL black then its not a leaking injector. Its more likely some sensor error or the ECU dumping fuel in for some reason.
If only ONE is black then look at that cylinder. You would notice a missfire on that cylinder.
If NONE of them are black and your getting bad economy then..... NO Idea.
BTW I had a missfire when the O2 sensor was dead. Missfired from running too rich. AFR's were 9.7 to 10.2 when cruise. 250ks to tank.
my pesonal experience is different. before i was getting 400+kms per tank. now ive replaced02 sensor and sparkies and im only getting 250-300ish!!!!
and still stock ecu etc.
Just finished a full tank after the ecu 'touch up' by RE customs. I manged to get 310km and 1/4 of that was done on the dyno, so it has made a decent improvement.
I CBF changing the fuel filter and checking the plugs the w/end but will do it next week and see what happens.
Nick
well i just got 675km (9.5L/100km) from that previous tank of petrol, that should be some incentive to stop being so lazy and change the filters ;)
Only just read then that yours is 200kw, mine is stock standard apart from the exhaust but that extra 50kw shouldn't cause that much different in fuel usage
well i just got 675km (9.5L/100km) from that previous tank of petrol, that should be some incentive to stop being so lazy and change the filters :/
Okay, but there is no way you have managed that in Melbourne peak hour traffic. I might drive my car to Sydney for Xmas, so I'll see if I can tailgate a truck the whole way and beat that figure :(
I will change the filters and plugs this week sometimes, I know I'm just being lazy. But after the work Xmas party Friday night I lost all enthusiasm do do anything but sleep it off!
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
