  • Replies 318
nice one Steve!! Hope you still have the 32!
Is it set up for track, sprints, rallies?
drop me a pm if ya like mate - actually, please do - Ive been keen on something like that fir a while!
mate its a little club car with a half cage surge tank sr20 engine and gearbox nothing special but something great to start off with i think its setup to run anything club the guy recons it goes about as good as a xr6 turbs
and yeah still got the 32 but not for long cant get a heavy enough tow bar and i am gunna try get in to the racing alot more now.
ok I want to come to this, is there anywhere I can go in Sydney or will there be someone there on the day for me to join the club and apply for a temporary licence so I can get on the track?
also what are the car equipment requirements such as helmet, fire extinguisher...etc. Where do I buy a helmet and what kind of helmet qualifies?
Edited by Edge
Edge,
Im not really sure about your first question - Duncan? help? :bunny:
Helmets - Any ADR approved helmet is fine! Sydney City motocycles have some good ones, I got my mrs a helmet there - saved $30.00 as I am an SAU NSW club member (another benefit to join!!)
And fire extinguishers - 1kg or bigger thats attacted inside the car close to yourself.
Just make sure the car is in tip top condition. No leaks, no loose items inside the cabin or boot. All fluids are good - oil, power steering, brakes - even bleed brakes if you can
You'll need long sleeve shirts and pants and closed shoes.
Im pretty sure thats it!
i shot edge a pm re this, but basically to join on the day you need a club exec to vouch you are a member of the club (of course you can join the club on the spot). Once a club offical has confirmed you are a member the organising club (in this case NSW RRC) or SAU NSW can issue you a L2S on the spot which includes a 21 day temporary license for the paperwork to get to CAMS and back.
So its easy to do on the day as long as an exec member is there and you (or the exec) brings a form with them
if u get a fire extinguisher make sure u get one with a metal bracket n clip
as i have seen officials say no the ones with plastic brackets
hey guys, i'd love to come to one of these days...
what the go with licencing. i am a member of sau...
will someone be there to say 'yes he is a meber of sau and he can get a cams licence' or should i get a cams licence in the next few days?
Thanks, does the metal bracket need to be properly fixed with screws into the metal body or is it ok onto the plastic of the car?
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
