god I love my car.....so much fun!!!
and I hate wrx and evos....damn shopping mobiles that goes around corners quicker then me grrrrr
never knew how much fun my car ACTUALLY IS till today :happy:
  • Replies 318
i'll be back once only when all the necessary mods are done, might take a while but the next time I hit the track, no more pussy footing around and none of this keeping the revs low so I don't over heat kind of crap. I'll be back with a better handling car.......so watch out all.
i'll be getting swaybars, oil cooler installed, proper wheel alignment, will try to fit a 4 point harness, will also try to make some cooling ducts for the brakes. New brake fluids and a good bleed. GTR wing for more downforce.
well i did end up making it on sat to the track and if you think sun was quiet you should have come on sat there was only about ten cras through the whole day and i was one of them had a great time the car went good except a cloged fuel filter but was great to get out i might be going to one of the next ones early next year to give it another run. In the arvo i had thhe track to myself just for a drift session cause everyone else was to scared to get out when it rained. and the day was good cause they just let us go when we wanted no class separation.
people who are scared to go out on track just because its wet are majorly soft.
admitefly one was mal rose and he only had slicks. but it was good there was plenty of track time im hoping to go out again on either the 2nd 5th or 6th if im allowed and if i can afford it anybody else going on any of those dates?
hey guys, i think im gonna go on the 28th of December...
anyone else thinking of going?
ive never been before...this should be intertesting...
does evenyone go stupid fast or can you just go at your own pace? (not something silly like 60k...faster than that...)
hey mate good luck for your first day out - the main thing is to take it easy and build up speed carefully - and always pay attention, loosing concentration for even a second can be a mess.
just work up to speed once you are familiar with where the track goes, go nice and quick on the straights but treat the corners with care until you know how the car handles it. Also brake hard and early until you are sure of the speed you can make each corner.
start out easy and you'll have a ball!
Duncans advice rocks :)
As well as being safe and learning you and your cars limits, you MUST have fun!! :thumbsup: Its always important to come back in with a smile/grin on your face :)
James and Albert - go some whiteline sway bars from sydneykids group buy
and for the handbrake - meh, just get a drift button ;) mine works a treat!
drift button yo!,
yeah ill pm sydkid in abit
Waffles- I pop my track cherry last week :)
just ask everyone who were there how much fun i had :)
especially duncan! :thumbsup:
but nuh, you WILL enjoy youself, make sure you take it easy during your first lap, and work your way up as duncan said, is all from experience ;)
oh guys you rock, thanks for all the advice. im gonna take it real easy as i have just had my baby fully resprayed. but its crazy how quick the stone chips come about..grrrr
however im not so precious that i wont drive my car like it should be driven, hence the easy start into track time....can do all the great performance mods without stretching her legs!
ha ha ha i had just resprayed my front bar a couple of weeks ago, now i'll have to redo it again. this time gotta give it a few more coats and extra few coats of clear coat just in case
BTW frozenwaffles, as James will tell you - the most important thing to do before you get to the track is to bleed your brakes properly with good brake fluid like Motul RBF600. Nothing will stop the fun quicker than having no brakes left after 3 laps when you get to the end of the straight......
BTW you guys....handbrakes are for holding cars when you park them on a hill, not for track work :thumbsup:
    • Can perhaps see how the R33 appreciators would think so.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
