god I love my car.....so much fun!!!
and I hate wrx and evos....damn shopping mobiles that goes around corners quicker then me grrrrr
never knew how much fun my car ACTUALLY IS till today :happy:
  • Replies 318
i'll be back once only when all the necessary mods are done, might take a while but the next time I hit the track, no more pussy footing around and none of this keeping the revs low so I don't over heat kind of crap. I'll be back with a better handling car.......so watch out all.
i'll be getting swaybars, oil cooler installed, proper wheel alignment, will try to fit a 4 point harness, will also try to make some cooling ducts for the brakes. New brake fluids and a good bleed. GTR wing for more downforce.
well i did end up making it on sat to the track and if you think sun was quiet you should have come on sat there was only about ten cras through the whole day and i was one of them had a great time the car went good except a cloged fuel filter but was great to get out i might be going to one of the next ones early next year to give it another run. In the arvo i had thhe track to myself just for a drift session cause everyone else was to scared to get out when it rained. and the day was good cause they just let us go when we wanted no class separation.
people who are scared to go out on track just because its wet are majorly soft.
admitefly one was mal rose and he only had slicks. but it was good there was plenty of track time im hoping to go out again on either the 2nd 5th or 6th if im allowed and if i can afford it anybody else going on any of those dates?
hey guys, i think im gonna go on the 28th of December...
anyone else thinking of going?
ive never been before...this should be intertesting...
does evenyone go stupid fast or can you just go at your own pace? (not something silly like 60k...faster than that...)
hey mate good luck for your first day out - the main thing is to take it easy and build up speed carefully - and always pay attention, loosing concentration for even a second can be a mess.
just work up to speed once you are familiar with where the track goes, go nice and quick on the straights but treat the corners with care until you know how the car handles it. Also brake hard and early until you are sure of the speed you can make each corner.
start out easy and you'll have a ball!
Duncans advice rocks :)
As well as being safe and learning you and your cars limits, you MUST have fun!! :thumbsup: Its always important to come back in with a smile/grin on your face :)
James and Albert - go some whiteline sway bars from sydneykids group buy
and for the handbrake - meh, just get a drift button ;) mine works a treat!
drift button yo!,
yeah ill pm sydkid in abit
Waffles- I pop my track cherry last week :)
just ask everyone who were there how much fun i had :)
especially duncan! :thumbsup:
but nuh, you WILL enjoy youself, make sure you take it easy during your first lap, and work your way up as duncan said, is all from experience ;)
oh guys you rock, thanks for all the advice. im gonna take it real easy as i have just had my baby fully resprayed. but its crazy how quick the stone chips come about..grrrr
however im not so precious that i wont drive my car like it should be driven, hence the easy start into track time....can do all the great performance mods without stretching her legs!
ha ha ha i had just resprayed my front bar a couple of weeks ago, now i'll have to redo it again. this time gotta give it a few more coats and extra few coats of clear coat just in case
BTW frozenwaffles, as James will tell you - the most important thing to do before you get to the track is to bleed your brakes properly with good brake fluid like Motul RBF600. Nothing will stop the fun quicker than having no brakes left after 3 laps when you get to the end of the straight......
BTW you guys....handbrakes are for holding cars when you park them on a hill, not for track work :thumbsup:
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
