  • Replies 318
Whats my sau member number Duncan? I am going to be buying a helmet too.
Hey Albert when are you going to buy your helmet. I'll come with you perhaps they'll give us a better price if we buy 2 at once?
sending you pm
you have msg mate :blink:
My god I'm excited.......finally I get to do a Oran Park GP track
anyone got a few stop watches handy?
Hey james which day are you going in?
scoobs, can't wait to see your toy, its great to see another race car in the club
sheng and any others, I can provide a license for club members on Sunday. And I can organise membership for anyone new.
We got helmets today :)
also the CAMS approved fire extinguisher was $32.99 at Repco
Are black leather shoes suitable, or do the shoes have to be covering over the ankle?
got my for 29.95 from supercheap :P
got mine for 27 from auto1!!! :P
Edge - it will certainly make a difference if you bleed the whole system and fill it with dot5 etc
even without that, you sould feel a difference im sure.
scoobs, weather depending!! :)
Don't worry too much either way about the discs unless your old ones are rooted. - but it is a very good idea to bleed the brakes with a good fluid like motul rbf600. Average brake fluid will probably boil up, and good quality fluid needs to be replaced every 12 months anyway.
Daniel I've never been questioned about shoes, although I guess thongs are probably out of the question. You will need long shirt and pants I normally wear jeans and long sleeve cotton tshirt (cooler for this time of year)
BTW has someone double checked that these days are still on?
I rang them a few days ago and it was still on.
I just noticed my right side front sway bar bracket has snapped! :P not sure if I can get a replacement - I'll try to visit Justjap and get a replacement tomorrow morning. Rang them, got the cleaner there who said they havn't closed for Christmas yet
Do you think the rain in the morning will make it so there is more track time to the people who turn up on tomorrow on Saturday?
Since I'll probably be fixing the link on my car in the morning this might work out well.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
