***EDIT... The CA18DET has been rebuilt 1500kms/2years ago with standard ACL parts.
1990 silvia Ks, car is unregistered, but has been complied.
CA18DET
5speed manual
GT2860R turbo
Xtreme 5puk clutch
SS manifold
3inch dump/front pipe and full 3inch exhaust with muffler for road use, and 'muffler out' pipe for track
600mm FM intercooler with SS piping
SS intake pipe
RB25 S1 80mm AFM
GTR injectors
Bosch 040 fuel pump
R32 Skyline radiator, Spac cap.
Dr.Drift re-mapped ECU
K&N pod filter
Advancedjap oil catch can
SR20 front brakes, and EBC green stuff brake pads
Maltech braided clutch line (factory hydraulic box removed)
Maltech braided turbo lines
18inch wheels
heaps of 16inch wheels, semi slicks etc etc
GRE fixed back drivers racing seat
Greddy profec EBC
BES turbo timer
Greddy boost gauge - LARGE!!
Short shift kit
G13 handbrake button
Solid gearbox mount
Tein HE front coilovers and camber tops
Tein HR rear coilovers
D-project front castor rods
D-project rear camber arms
D-project steering rack bushes
G13 alloy steering shaft spacer
Cusco front strut brace
G13 rear strut brace
D1 quick release steering wheel kit/spacer
Bride woodgrain steering wheel
Razo shift knob
Razo pedals
HID headlights
Square headlights
Vertex copy sideskirts
Chargespeed copy rear bar (slight damage)
Tinted tails
Single wiper
Dmax copy bonnet vent
Kenwood CD player. pioneer 6inch rear and some speakers in the doors
Timing belt, drive belts, water pump, various water and fuel hoses, thermostat, front brakes, have all been replaced recently.
This car started life as my daily driver, then I got into drift, and modified it to suit. Now due to personal commitments I would like to swap the car for something more 'streetable', or sell it. The car has an auto viscous LSD, which has NEVER single-spun once at the track, but recently driving the car it will intermittently single spin. I have a manual S13 diff getting welded, so that can come with the car. This car has spent huge man hours setting up the front and rear suspension, with the power level, it is a very fun car to drive. Last tune at Dr.Drift was 190RWKWS @ 16psi, which shows a healthy CA18. There is no coolant or oil leaks, The bonnet that is on the car is dented and pretty rough, the perfect condition stock white bonnet comes with the car, As will a set of untinted tails. The front left guard sustained a dent, and has just been hit out with a ball pein hammer, its rough, but the car is a drifter…. I have many pairs of rims that can come with the car if required, which include a set of 18s, 3pairs of 16s, and a few stockies.
As the car is unreg’d, it would suit a track only car. But as it has been complied, it could also be returned to a street car if you so desire to go through the work to obtain a RWC.
Im after $8k as is.
Call 0409936117
CAR IS IN MELBOURNE
Edited by PSI929
could you please post some pics
how many hours do you think the car has done on the track?
and as for service... ?
i am preety keen i just would like to know abit about the cars track life
cheers
hey, pics have been posted. Ive raced the car on the track at approx 10 meetings. Calder and Winton only.
The car is probably over serviced. I give it a thorough going over before i hit the track, and service it on return from every meeting.
Pass on the details on the auto/non turbo silvia, and how much cash adjustment you plan to give me.
Thanks guys
    • Salut Frederick. Belle 370z. Welcome to SAU!
    • Hey, it's me! Though honestly, if I had 20M in my bank account tomorrow, I would not want to be rid of my car all of the sudden - Which makes me think this is money stuff, not "I actually hate car" stuff. I'd probably double down and buy even more trinkets and fun things for it. If this is not you, then sell it cheaper. It will sell at a certain price after all.
    • This is the LCA mount reloctaion kit. Self explanatory in its description. https://au.gktech.com/products/s13-180sx-r32-subframe-anti-squat-reduction-weld-in-kit?_pos=62&_fid=1e812d392&_ss=c These are the alloy subframe bush inserts that I am using. I like them. https://au.gktech.com/products/rear-subframe-slip-in-collars?_pos=29&_fid=1e812d392&_ss=c Alternatively, if you have original and shitty bushes, you might consider outright replacement with poly. https://au.gktech.com/products/polyurethane-rear-subframe-bushes?_pos=28&_fid=1e812d392&_ss=c I would also higly recommend that you look into adjustable RUCAs and tension rods, so you can sort out the camber and bump steer behaviour, especially if the car will be any more than ~15mm lower than stock. I would also highly recommend the GKTech FUCAs, although you really should do some research and learning on the subjetc of R32 FUCAs before making any decisions. All of this will be criticaly difficult to get through a TÜV inspection too, if that happens to be relevant to you. Note that if you do install the relocation kit, you will absolutely have to replace the associated bushes with spherical joints (you can read all about that on the product page) or upgrade the LCAs also.
