I have recently imported a 1997 R33 GTST skyline and was wanting to put in a turbo timer myself. I did quite a bit of research and found the one that i wanted which was the HKS type 1 turbo timer. I bought this and the harness and have been installing it today.
The car has a basic immobiliser.
I installed the harness fine and it works showing the battery voltage but because the skyline ECU is located next to the battery in the boot i am stuck trying to install the rpm Brown wire and the blue speed wire because i do not know where the ECU wires go. I have the pinout diagram of the R33 ECU and know what they need to be connected to but the turbo timer wires will not make the distance and i was hoping that they will come out under the dash but i am not sure which ones?
I was wondering if anyone has installed the HSK type 1 turbotimer into their R33 and if they have could they please give me a hand with info on where to connect these wires?
Thanks Heaps!!!
ok first problem here is that the ecu is not in the boot! its behind the passenger kick panel on the lower left of the footwell...
WTF i'm no stupid. When u take down the divider between that compartment it is practically in the boot. All i need to know is where the wires from the ecu go (rmp and speed).
If u havent got anything helpful to post don't post then
geez, he's trying to help you and you bite his head off!
keep looking in the boot then and let us know how you go when you have it installed
Whats it doing back there?? Have you had it moved, cause last time i checked the HICAS steering-ECU sat back there and the ECU on my GTST (which i changed 3-4 times) sits near the passengers feet, behind the panel...
Anyways mine came with one installed, it was all in the harness, just plug and play... Know that since i removed it some months ago.
Hope it'll sort out!
Cheers!
  • 1 month later...
Hi all, I have recently puchased one of these units as well, unfortunately it didn't come with an R33 plug. Lucky for me I have wired up a few things before. My question is, are there any harnesses off the steering column that will allow me to avoid having to wire all the way to my ecu? does anyone have a wiring diagram for the steering column?
Cheers, Dan!
Last time I checked my ECU was at the passenger footwell too!
wrong!
its in the boot because he says so!
PS: good luck wiring your turbotimer to the battery / fuse box etc. should work a treat!
gold.
  • 2 years later...
  • 7 months later...
    • Hey everyone!!  I've noticed that whenever I do my oil changes, after putting 4L in, the oil level sits at the top mark in the dipstick. This is after letting the old oil drain for a very long time too! I've checked the oil level daily for the past few mornings. It happens every time and it's confusing because all the threads say that it should take about 4.7L (With some just adding the full 5L) My next thought is to figure out if the dipstick I have is correct so could someone please tell me the length of the RB25DET engine oil dipstick?  I've checked images of some of the genuine dipsticks, but none of them have the length in it. https://justjap.com/products/genuine-nissan-engine-oil-level-dipstick-fits-nissan-r34-skyline-c34-stagea-c35-laurel-y34-cedric-gloria-rb25de-t-neo?currency=AUD&srsltid=AfmBOortQXofgmiHVRKuIaiKuygL4k0Ewp68c3isGZk0vvKOJ7Yqf3iB However.... the engraving on the genuine ones say 05002 while mine says AA000. This makes me believe that maybe I have a wrong dipstick? I just want to confirm before I buy a new one. The car is a fresh import from Japan so I don't have details of the previous owner to ask him. Thanks in advance 🙏🏾
    • Sport. I didn’t rebleed it cause I just removed the slave and left connected.    I will change line and slave and see how it goes.
    • Oh and how is the rattle when foot is on the clutch ?
    • Did you get the sport or track ? From what the documentation says the uniclutch has a small amount of movement to disengage.  So your story of tricky pedal setup seems common.    Hopefully you got it bled up too, as the bite point moving around is usually either plates wearing in or air in the line.
    • There's always "MIG it up and grind it back".
