hi all,was wondering if anyone has stripped or knows someone that has stripped an R34 GTR with mods to sell since i am having trouble selling it as a complete car?
How much would all the parts return me?
Hassle involved?
or just be patient and a buyer will come along.
thanks Anthony
https://www.sau.com.au/forums/topic/196288-stripping-r34-gtr/
I'd imagine that stripping the car would be bad in both cases. You'll most probably won't get as much as you would if you sold the car as a whole and it'll probably take longer to strip and find someone to actually buy the parts.
Just wait till someone comes along with the amount of money you're happy with in my opinion.
there just seems to be a lot of interest in R34 GTR parts....a tuner was after a 6 speed gearbox the other day and he told me he would buy the shell off me also but that is in Brisbane so postage is also a problem unless sold in Sydney
As said in general the complete car will sell for more than the second hand parts. The exception to this is the mods. People are often interested in aftermarket gear. Saying that I'd love a 6speed gearbox.
The hassle of stripping a car is too much unless you have to strip it.
You really only get good money for the main bits...
ie. Motor, gearbox, etc
Its all the little bits that are worthless, plus you will find people after stuff you need to further strip and then may be difficult to sell then...
ie. "I want your rb26 head" then you will find it hard to sell the block for instance...
Keep it together, wreaked GTR's are for parts, if its registered atm keep it that way...
ok thanks people....it will stay complete....if you know anyone interested in a GTR it is listed on carsales and under this site under my username...
thanks Anthony...price is negotiable
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
    • Twas your car many moons ago that gave me the idea!
