I had 18x9.5 +12 TE37's on my R33 GTR and they fit pretty well, filled out the guards nicely, but with a 275/35/18 I got some minor scrubbing on full lock so I'd go a slightly thinner tyre...mine are currently for sale if you are interested :rofl:
I now have 19x10.5 +22 CE28's and they fill the guard out just as well, I wanted the fatness and that tough dished look of the 10.5 but didn't want the scrubbing so I went with a 265/30/19 for a bit of a stretched look and they don't touch anywhere, ever now!
Edited by QIK_GTR
I had 18x9.5 +12 TE37's on my R33 GTR and they fit pretty well, filled out the guards nicely, but with a 275/35/18 I got some minor scrubbing on full lock so I'd go a slightly thinner tyre...mine are currently for sale if you are interested :P
thanks man, would 18x10.5" rims +15 be cutting it close?on say a 265 rim?
can you post some pics of your ce28s, must look crazy!
I'm not really the right person to be asking about offsets, I made a thread in here to ask about them myself!
I'll try and get some pics taken this weekend, would prefer to wind the coilovers down a little beforehand to get the stance right, so we'll see how I go.
please post pics peiople, really need to see what im getting.......even the ce28 pictures would be great help.....
Question...
would a 18 x 9.5" et12 te37 wheel have the more deep spoke look compared to a 18 x 10.5" et15 te37 wheel? since the offset is less on the et12, but the rim size is bigger on the 10.5" obviously....which one will give the more deeper spokes look?
ok, well here is a pic I took yesterday arvo, not really one I want to post because the car is filthy, the wheels are filthy and I want to lower it more, by quite a few turns on the coilovers to get the stance just right.....but just to give you an idea.
CE28N 19x10.5 +22 265/30/19 Federal SS-595
TE37 18x9.5 +12 275/35/18 Falken - could've been lower for a tougher look, but 18s are bit small in my opinion on a 33
TE37 19x? +? - just to show you how a 19in looks with what I call the right height, whereby the front has a little clearance from guard to tyre but the rear sits nicely just on top of the tyre.....which is the whole reason I went with 265s not any wider.
Well I don't use the car to go round corners overly fast, I'm more of a straight line guy, but yes I hear what you are saying.....but I'm talking maybe 1-1.5cm up front and maybe a tiny bit more down the back, just to have the guard sit a little closer to the tyre, maybe a looks thing, but I don't forsee me doing many mountain runs where its going to have a major impact!
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
    • Does anyone know if this is off centered? Looks like it, when I indicate to go right, but turn my steering wheel slightly left it cancels (was always like that even before I started messing around with it) was wondering if anyone else has the same issue?
    • Nothing photo worthy since last update, lots of little plumbing bits for the AAC/Cold start valves, and unfortunately I still need another couple of parts for the brake booster line and the AAC into the plenum. Otherwise it all looks good to start up engine wise, onto checking the electrics/interior
    • Good news mate, plenty of spares available 5:40
