1990 Ca18det
1990 Nissan 180sx
Motor: CA18DET Manual
KMs: 160XXX
Colour: Burgandy
Rego: Feb 08
looking to upgrade, car has been good to me over the past 3yrs, but the time has come to sell.
Motor:
- CA18DET
- T28bb turbo
- Pod filter
- BOV
- new battery
- replaced stock radiator with aluminimum one
- cat back exhaust
- heavy duty clutch
Interior:
- momo steering wheel
- turbo timer
- boost guage
- cd player
- cheetah alarm
Exterior:
- lowered springs
- unknown 16" wheels (6mth old rubber)
- spoiler removed
- few pin dents down passenger side
- unknown side skirts
- black CA front bar
car will come with 6 spare wheels (all 15's)
also comes with FMIC (brand new still in box)
minor accident history, small front end damage. hence the black front bar. all straightened now.
got plenty of the papers for the car (import approval and all that jazz as well as bits and pieces bought for the car and any work done to the car)
always fill up with BP Ultimate, always changed oil with motul. only running low boost.
looking for $7800 but negotiable. sorry, not interested in swaps
PM if interested
PICS CAN BE VIEWED AT
http://www.nissansilvia.com/forums/index.p...howtopic=272562
 Share
    • You don't need an AC mechanic to fit it. You do need one to vac the system down and fill it. That's how you get refrigerant.
    • Well, it's actually probably worse than you think. I think you have to (minimally) install GKTech's spherical bush replacements to the lower arm's inner ends, because you absolutely cannot subject the original (or poly) bushes to that much misalignment. The better option being to replace the whole lower arm with GKTech's unit. This brings sphericals to the lower inners either way you do it. And are you aware that the kit is weld in and you have to take the subframe out of the car to get it fitted? It's a fair bit of work. These issues both drive my ongoing dithering about doing this to my car, for the last couple of years.
    • The website said you need a AC technican to swap it in. Is that true? How did you fill the refridgerant? Was it easy to install?  If i just got the bracket and the new smaller AC compressor, would the other components be compatible with R134?
    • Hi All Finally getting back to work on the R32 this weekend and had a quick question about the GKTech anti squat kit (https://au.gktech.com/products/s13-180sx-r32-subframe-anti-squat-reduction-weld-in-kit?_pos=39&_fid=eb6b5077e&_ss=c) So, this straightens out the rear LCA and increases the roll centre by 20MM which is great BUT I also have MFR roll centre adjusters (https://www.rhdjapan.com/moonface-super-lap-rc-joint-roll-center-adjuster-bnr32-ps13-rps13.html) which gives a +15MM lift. My question is whether they can/should be used together or if its going to massively effect the geometry? In my mind, I can't see that they work together but was hoping for some feedback on someone who has done this before deciding which to use or if both?   Thanks
    • Agreed. Thing has to be running absolutely pig rich as well. I would worry a lot less about your idle and start going through all your electrical before the car burns down.
