I have set of R34 GTR Wheels
I'm considering selling just the wheels (NO RUBBER) to make way for my new ones.
Forged rim and measured 18x9" 30+Offset.
Comes with Centre Caps.
Wheels in good condition. 2 x Wheels has lightly gutted rash but not so visible.
Price: $1700
Interstate shipping available
Not in rush to sell, if i don't sell, i keep it as track rims instead.
Email [email protected] if interested.
SOLD
Cheers
Edited by lazzy8oy
https://www.sau.com.au/forums/topic/196327-fs-r34-gtr-wheels-sold-sold/
these wont hang out at all aslong as you do not have stock suspension
they are a 9JJ +30... they are nothing crazy at all
will sit in on 33 and 34 guards and the rears should sit out slightly on a 32 4 door
    • Apologies, while id like to put the MAF as close to the TB and relocate the recirc, this may be too much work. Will most likely end up just putting it on the original AFM spot ( onto/next to the airbox ).  Was going through nistune, found a pretty nifty doc on this. Nistune MAF Notes. Also, i was looking through the bay, and there seems to be a tube/line connected from the A/C to the intercooler piping ( Between the smic and the recirc), what does this do as the crossover fmic piping doesnt have any connection? plumbing? not sure what you call it but the nipple thing ahah.  Also, been reading up more about crossover fmic in regards to the legality of having the hole drilled for the piping, this would most likely need to be engineered right?
    • My advice is if you need a big build done do it in Japan. The yen rate is so favorable and there are shops that can be genuinely trusted and not micromanaged/carefully monitored every step of the way. Garage Yoshida is obviously my preferred option but they're so busy these days and all interaction with new customers has to be mediated through BBL/Toprank now.
    • I haven't....but a poorly made one would terrify me. Surely a good second hand one is the go, as they don't work hard and no-one wants to keep one after they are finished with it A big consideration would be the weight of the shell you are putting on it....is it a fully dressed chassis or just the body
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
