Hi robo i met you once to pick up the gtr blow off valve a while ago, I have still got the 33 gtst and recently purchased a rebuilt r32 GTR and it is fantastic i am loving the handling and the power so i would say upgrading to a r33 GTR you would love it.
When I had my GTS-T, I never really bothered thinking about the upgrade. Just loved the GTST for what it was and enjoyed it! However, when you drive the GTR, you really love it... just the way it drives, it's got a real presence to it and just feels so tough... good times, I recommend the upgrade :P
Besides, Evo's are boring.... well, not for the first six months haha, until you realise the car will never do a thing wrong and drives itself. A GTR is a much more rewarding drive! (I owned an Evo for over a year before the 33 GTR). If you want to get quick numbers around a race track, then Evo is the best choice, but it's not as rewarding to drive. I can see your into drags, I wouldn't buy an Evo at all if you are....
Edited by TommO
When I had my GTS-T, I never really bothered thinking about the upgrade. Just loved the GTST for what it was and enjoyed it! However, when you drive the GTR, you really love it... just the way it drives, it's got a real presence to it and just feels so tough... good times, I recommend the upgrade :)
Now if only i could get one to have a drive in :)
The only person i know that has one is pushing 429wkw, so thats a bit unfair comparison :D
youd be right.
but your gtst's suspension may be farked or maybe not setup right (if already aftermarket)
Im actually reall impressed with the Stock suspention in my 33, keeping in mind it has only done 50,000km, its very very firm! Id be safe to say that it feels a little better than my stock Integra Type R suspention did when i got it.
WOW. I feel the exact opposite re my suspension. it is stock, has done 90k kms. Maybe it's partly the diff that is causing the problem.
If your suspension is better than a stock Type R I can understand why you would be really impressed.
A GTS-T is a monster, A GT-R is a monster's monster.
Do the maths...
Stock for stock, I wouldn't really call either of them a monster. There actually pretty avarage cars, they just have alot of potential.
If your thinking about buying a GTR it's pretty irrelivant if it's got this or that or whatever doodad, go drive a few and see what you think, there such different cars. The 4wd is good but it isn't for everyone, just depends what you like really.
and you can confirm that they are "THE SAME" suspension bits that were installed on your car in 1998?
NO.
I find it very hard to believe ANY stock suspensioned skyline handling better than a stock DC2R or DC5R
NO.
Dude, chill out. I said it FEELS better. I didnt say it was :s
My ITR when i bought it had done 99,000km, so it had double the wear on it. So when i compare the suspention that I owned, then the Skylines FELT better.
Its definatley firmer than the ITR was. But then again so was my mums Toyota Curren, but that had dont 30,000km. Its all about wear and tear. I bet a brand new stock ITR is hard as hell.
    • Yucky. Things haven't gotten any better though. Now you have Emerson and Honeywell pushing these massive DCS/Scada things with proprietary hardware. They're not a PLC, they're not a computer, they're a...distibuted PLCish/DCSish monster of thing, that only they can program because they make the barriers to entry for anyone else so fricking high. And their developers are all located in the third/developing world (and India, in case anyone does not include that place in that category) and there are terrible failings of the ESl variety, of the care and common sense variety, and f**king forget about Functional Safety. Not a one of them has any idea what it means to comply with an IEC 615xx series standard.
    • All of the ECU grounds are to the chassis, the IGN grounds are to the cylinder head and i believe all the OEM body harness are left in original locations, im trying to work out if i can tell if the sensor voltage itself is losing any power to it from the very low ECU voltage. But yeah a manual pressure gauge will help in picking which path to actually chase. Also please dont bully my wiring plan i never designed it to be universally understood hopefully it still can make sense to you, im a wiring virgin.  1 thing i have just noticed the pressure sensor in question relays both pressure and temperature, the temperature reading holds nice and steady despite the low ecu voltage but the pressure reading is the one that jumps around alot so maybe it is really a pressure issue? wiring plan.xlsx
    • Gday, Due to not finding much up to date info on this topic I thought I'd make a thread to get peoples latest opinions/recommendations. Background info -  I've got a S1.5 R33 GTST as a fun project car, mainly for street use and occasional drag strip, apart from all the cosmetic things I'll be doing a full rebuild of the engine with forged internals. Since it'll be getting new cams (kelford) and springs to match I thought I might as well get new lifters and valves while I'm at it, the dash says 160k KMs but the engine seems pretty tired, compression measures about 130psi across all cylinders so I'd like to freshen everything up. This is where I'm tempted to just fork out the extra and go solid lifters while it's all apart, aiming for 400-450kw atw with a flex tune. Assuming all supporting mods (oiling, fuel and all bolt ons) with a lightly ported head and turbo to match (yet to make a decision possibly gtx3582r or similar from Hypergear) I've seen the Tomei kits with just the buckets getting around, Supertech sells most things - Supertech High Performance Cam Followers | Trusted Racing Cam Followers Questions -  Has anyone found the Hydraulic lifters to limit them at this power level? Is it usually found that you can just clean the stock lifters and find they work fine?  Does going solid lifters save any headaches/issues with hydraulic lifters in the future? Any recommendations on other things that will need to be replaced, I know I'll need to get the solid profile cams but can you use the same type of valves and springs/retainers and is it recommended to change the guides and stem seals?    Summary -  Basically looking for pros/cons and wanna know if I'll actually need the extra RPMs from solid lifters or it'll just be bragging rights to say it ReVs OvEr 8000 Cheers
    • Ha ha ha, this stuff they had was installing Toshiba PLCs that were made some time in the 1990s, and they were replacing GEM80 PLCs. To let those two talk (staged upgrade along a ~1.2km long building that was split into 4 sections), was a bunch of WinXP machines running Java gateways... There was no way to put something like ProfiSafe in... Most of the HMI machines were WinXP, with Java program, with a custom button board emulating a keyboard... About the only buttons in the operator stations that went direct to the PLCs was the eStop. There was some interesting design stuff in that place...
