Hi guys,
It has been a while :P Life is busy...
Anyway, I need to replace the turbo on my Stag - the original is whining like a jet about to take off. Unfortunately, the cash is just not there for a serious upgrade, so I am looking to replace the turbo with something pretty stock, that will involve nothing more than bolting in and fitting up. I don't want to have to worry about wrong intake/outlet diameters etc, so can anyone tell me what the specs are that MUST be right to make this as simple as possible? And any idea what I should get? I just enjoy driving my Stag, I ain't a mechanic or a fanatic, so I really have very little idea.
TIA, and, it's good to be back, even if it is for the wrong reason...
Sk0pe
Hey Sk0pe,
if you can't get a healthy standard used turbo (the s1 Stagea uses the s2 R33-spec turbo), then I believe the best replacement is a Garrett GT28RS, which AFAIK is a direct replacement.
Your best bet is to give a workshop a call and check with them, or speak to GCG who sell and rebuild turbos for Garrett.
Here's a few places in Sydney:
GCG Turbochargers: 1300-TURBOS (or 1300-887-267)
Unique Autosports: 9620-9000
Hills Motorsports: 9899-9962
Good luck!
T3 flange, with rb20/25 exhaust housing
Either R33 or R34 "Neo" turbo are bolt on standard turbo's
an R32 turbo would be a backwards step - small exhaust housing
scour the for sale ads for a high flow turbo
or take your shagged turbo in for a rebuild, where they bore out the intake and exhaust and use new core and new bigger steel wheels
(and compare the highflow quoted prices against the GT28RS)
search ebay, sometimes a R33/34 turbo comes up for sale
how would a gt28rs compare to a highflow? a mate is selling one cheap, brand new, as he decided not to fit it.
Not sure, but this is something I'd like to know as well.
Almost forgot about Just Jap - they have a good selection of turbos too. http://www.justjap.com
    • Hey guys! Y'all are the masters so figured I'd check in on a few items here. - My engine sounds ever-so-slightly more raspy than the other NA RB25s I've listened to. It's barely noticeable but definitely a slightly different sound. - When I back off the throttle at high RPM, I will sometimes get a pop out of the exhaust, assuming this can be diagnosed as misfire. Some history on the car: - Had an exhaust leak in auction sheet but was claimed to be fixed by seller (bought from USA importer).  - Car's coil packs and sparks were replaced when it was sold to me, but unsure on what the gap is and whether the coil packs are correct.  - A prior mechanic had misdiagnosed a pilot or throwout bearing sound as LSPI/detonation. Had played with timing a bit, pops/raspy sound of engine just got worse. Got timing reset. - Had failed emissions a few times. First time went in as is, failed. Second time, replaced cat, still failed, running rich as hell. Third time replaced o2 sensor, passed. Car still smells gassy though. - Timing belt and valve cover gasket also replaced.  - Gas mileage is... low. about 350-400K per tank.  Any idea if I'm having any serious issues here or does this all sound like normal old NA RB stuff and I'm fine to drive it with the pops/slightly raspy engine? If it'll help, I can get drop a video of the sound of the engine.
    • So....to find any R chassis part number, get your VIN (will be something like ER33-xxxxxx for you) and go to: https://www.amayama.com/en/genuine-catalogs/nissan and enter it. From there you have access to a web version of Nissan's part system, FAST. It is a bit tricky to get used to, so maybe have a shot and post up what you think.  You can also search by general model but note in some cases your car might have different options so VIN is safest.  On diagram 211 I got 14075-75T16 for Connector, Water Hose If I search for part 14053‑21U10 that you posted, that is also a water hose but not the one bolted to the plenum and 14075‑04U00 is the fitting where the water hose goes into the block.
    • Yeah now we are talking I much prefer coolers in the front middle because it lessens the chance of a small bump to a corner stopping the whole event. I was thinking the AT cooler can move out of the radiator, delete the AT/engine coolant interwarmer and mount a separate cooler with a thermoswitch somewhere further back as is common in racing, that would be one thing. Beyond that, the engine oil cooler is an obvious one to move to the wheel arch, potentially one on each side, but unused space is an issue. I did have a earlier pic with the bumper off but it doesn't show how busy the corners are: DS is full of the auto driving sensors and PS is totally fully of windscreen washer fluid reservoir But ultimately I was hoping to keep the AC, and the water/air heat exchanger is fundamental so it is not just the radiator that needs to be in front BTW here's airflow to the rad as it ran at the track (one horn is gone now and I'll remove the lights next time):
    • your right the maps for Australia came out in 2017 but are 2010 maps. i got the updated maps SD card put it in and it was the same. Same maps in my Brothers Nissan Patrol. 2020 i think his car is
