well my 4th gear clunks/ crunches, especially when coming down from fifth...
you cant shift down quickly and if you dont bring it down from fifth and for a split second leave it in neutral before shifting down to 4th then it crunches... and if your get up it a bit and change real quick from 3rd - 4th it sometimes crunches then too....
ive been told it is a lazy sinchro? so i had a lighter oil/ less thick put in to make it easier on it, but it still does it.. what is it? and what should i do to fix it?
also it might sound weird but when i put it in to 4th if as im doing that i kinda move it towards 2nd it usually wont do it...
1 3 5
2 4 R
if that makes any sense...
Edited by 02_FNE
https://www.sau.com.au/forums/topic/196397-help-4th-gear-clunk-crunch/
yeh its your syncro, done alot of highway racing have we?? or have you driven around at like 40km in 4th gear?? unless you want to pull the box apart and get it refreshed your going to be stuck with it...
and going over to second before you put it into 4th has got to do with using different forks in the box...i cant really explain that one to well.
have you tried double clutching? rev match.
well the syncro itself will cost you...35$ max from nissan or wherever. but the process to put it in is not as cheap... gearbox has to come out and pulled apart...
if you havnt raced or done any damage to the box then the previous owner probably did.
does it go in easier when you double clutch it? and rev match.
If your box is getting really noisy/crunching/grinding alot then you should look at trying some redline shockproof oil. Good for old worn boxes. Otherwise just use some Castrol VMX80 and some nulon additive, made my box feel almost new again.
Also as stated above always double clutch, it is much easier on your box.
ok cool, thanks for the help guys, ive also been told that i should replace the white nylon sleeve thing that the shifter stick sits into as it wears out and gets sloppy, so ill do that and also double clutch aswell as a treatment..
i know a few good peeps in the mechanics seen that might be able to help me out with getting the synchro changed..
it sh*ts me aye, i just want it right..
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
    • @KinkstaahKrinkle paint the "silver" alloy, not the red filter frame Engine bay heat won't be a issue worth worrying about as the silver alloy blocks it off on 3 sides, as for the top, the bonnet seals most of it and the big OEM CAI intake snorkel is still fitted in its original position  I will head into Clark's Rubber when I have some time to grab some pinch weld to tidy up the alloy after I paint it As for performance, I honestly wasn't expecting any, the only reason I got it is because the intake noise sounds cool to my old ears when I'm feeding it the beans Sometimes it's the silly things you do in in life that gives the most fun, and I do love anything that makes cool car noises In other news: I survived 4 nights at sea with Jackie not throwing me over board, holidays are continuing now as we are currently chilling at the Beachcomber in Toukley, after taking the coast roads from Sydney in the MX5, top down all the way, Toukley is where I spent a good deal of my youth holidaying during the summer months, there's lots of reminiscing going on,  and lots of beaches and old houses to visit Next on the list is to head to Batemans Bay for a few days, but we will take the Commodore out to stretch its legs, then Commodore hasn't really moved for months
    • There’s probably people who’d like to do it and then when it comes to putting their hands in their pockets they’ll all disappear into the shadows
