  • Replies 52
wrecking 1995 r33 series 1.5 nissan skyline
-it has a series 2 front which is no use has been smashed on the front and along the passenger side.
-has complete series 2 rb25det with complete engine loom and computer, turbo and lines, both manifolds, alternator power steering etc. engine has 68,000km's on it SOLD
- cross drilled and slotted front discs all calipers, rears have high performance pads- look like blitz ones (haven't checked yet) SOLD
-interior is still all good and in one piece except for driver's seat.
- has factory light up skyline boot garnish still in good condition.. $150
-series 2 rear spoiler with all LED's working $150
aftermarket parts
- genuine set of Nismo damper adjustable struts with matching Nismo lowered springs. all are straight and in very good conditon. $500
-has adjustable rear camber arms and front castor arms but need to check condition of these
- Nismo front and rear strut braces with brake stopper on front brace SOLD
-greddy profec b spec II boost controller- complete set up SOLD
-splitfire coil packs to suite series 2 rb25det $300
-complete stainless intercooler pipes including intake pipe for turbo that has port for plumback bov, replacement for standard crossover pipe and port for bov SOLD
-hks mushroom air filter with adaptor for airflow meter $50
- 3 inch mild steel dump pipe that joins to cat. SOLD
-Apexi copy pen style turbo timer SOLD
-genuine HKS super Dragger cat back exhaust 3 inch from cat to first muffler then 3.25 to resonator then 3.5 to huge stainless cannon with 5 inch tip. very good conditon SOLD
-Veilside side skirts RHS in good condition LHS has 2 small cracks which can be fixed easily. both painted in white. $150 pair
if your after any parts just ask and ill see what there is. pics will be up soon
pm or mark on 0433 960 414
Hi mate, I'll buy your LED from the rear spoiler if its still for sale for 40 bucks if you are keen.
Are you willing to sell the front seat headrests by themselfs? If so, could you post some pics and a price please?
hey mate i will take pics tonight and post them hopefully tomorrow
Hey
You wouldnt happen to have any parts for the air con
Im chasing the alloy pipe that runs from the receiver dryer to the condenser?
Please pm me asap if you have it
Thanks
Edited by bazr33
http://www.skylinesaustralia.com/forums/Ai...pe-t206706.html
The last post i did on this thread shows which pipe i am talking about
i will give ya a buzz tonight, to see if you have it.
Thanks
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
    • So I'm in the final stages of assembling my single turbo RB30/26 and had a question regarding MAP reference points.  I've seen several recommendations such as tapping the cylinder 2/3 ITB, tapping the intake manifold at cylinder 2/3, or using a point on IAC. First two are doable but require permanently modify part and the third is "out" as I plan to delete the IAC.  All that to say my question is can I used the "bleeder" in the center of the ballance tube as a MAP Reference? I'm running a catch can so I don't need it for the PCV system. My thought process is it "pulls" from all 6 cylinder, and it's between the ITB and the cylinders making it ideal for MAP reference according to what I can find. Thoughts?
