Future plans for us turkeys and our cars :) care of gordo
  • Replies 160
hmm - no major immediate plans for mine.
*Suspension ~ one day > happy with handling, it just sits too high
*FMIC ~ one day > stock one flows well enough for stock turbo anyway.
*Possibly upgrade clutch, like a twin plate or something, [would also lighten flywheel at same time].
*Couple of other 'little' things I will do very soon but they secret :)
ey andy, Ill stand there by the car if ya need me. I got a GREAT baseball bat ive been meaning to test out
hahahaa
but seriously, if theres any trouble, holla at me and youll hear me running from the other side of the building. (For ppl who havent actually met me, im kinda big:D:D:D:D)
Horus - HKS 2530's, spool up quick (approx. 3500rpm) and good for 1.4 bar. With other mods (powerfc, full exhaust, filters, adj. cam gears, ebc, injectors and fuel pump) should be good for around 310-330 rwkws.
Also providing you have a decent twin plate clutch to hold the power!!!
If I get a 180 or R32 probably will just go straight for the HKS 2530 or 2540 .. 2530 on an SR20DET sounds pretty fun.. that was the turbo i was going to chuck on my R33, but nah, cbf now -- too much money..
mmm... Funkey... you can take it off my hands.
but it wont come el cheapo.
only becasue it's got the t04e... extractors... ecu/loom..
All of which aren't cheap (extractors are 1-of-800 made)... but in the package you'll save.
remember it's making approx 190rwkw on the lowly 9psi :D
wat do you think it's worth? considering 250rwkw will be had with JUST BOOST. and nothing else :P
Future Mods: Weight reduction on the buggy and a 13B Turbo Conversion.....
Goal - 1:1 Power to weight (HP/KG)
Then we'll see who's quick jet!!!
Did a calculation and I reckon with 400HP, 400KG, a perfect launch, and traction = 8.1 @ 176 MPH!!!!!
SOme people think i'm a little cwazy?? I got no idea why??
Doc.
got my new project cars :D
should turn a few heads fitting an sr 20 to this just to be different and to make a wicked track weapon.
jet congrats on the car If I had the cash lying around I would have grabbed daves car in a heart beat. just learn to respeckt it as it bites :)
this is it b4 it dissapears into the work shop
nah mate not drugs common sense this is a very good and very popular swap
some reasons for the swap
1 no need for a custom plenum.
2 power fc bolts straight in
3 there are heaps of parts for them.
4. it makes the weight distribution 50/50.
5 there are no high profile ones and i like to be different.
6 I found some one who is willing to do the conversion for a reasonable fee.
7 the motors are more torquey.
8 the gearbox just had 2k spent on it in a full rebuild
9 the motor only has 80 000 genuine klms10 when I need to upgrade things like pistons and injectors I will only require 4 not six
and development on the rb20 is finished in japan
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
