Future plans for us turkeys and our cars :) care of gordo
  • Replies 160
hey ash.. time for some weight reduction? that is probably the reason those Silvias can take you..
Even 27, rating 1 for 3 years or something I wouldn't expect much change out of $4k a year for a GTR.. my gts-t costs me $1500 as it is
Originally posted by R31Nismoid
mmm... Funkey... you can take it off my hands.
but it wont come el cheapo.
only becasue it's got the t04e... extractors... ecu/loom..
All of which aren't cheap (extractors are 1-of-800 made)... but in the package you'll save.
remember it's making approx 190rwkw on the lowly 9psi  :D
wat do you think it's worth?  considering 250rwkw will be had with JUST BOOST. and nothing else :)
back to my question..
what would my motor be worht with the gooides on it?
wat does everyone think?
mmm... i'll be happy with 250...
but eventually... like i have now. I'll get sick of it and want more.
This is all about 12 months away... but yeah, i know what you mean meggala. 250 should be nice!!!
But on 215's i know what the end result will be... lol
but anyway... what is it worht do you think?
(even if i don't sell it) Out of interest at the moment.
Bearing in mind it's a series II motor with the VVT
CHINNY - u would need a bar made up customer if u want an R34 GTR front bar on a GTT
to fit a GTR bar u need guards AND a bonnet as the lights are different.... so it would have to be a custom one... perhaps someone like suborn could do this for u... redesign one to fit a GTT
You'll get used to 250rwkw soon enough and want faster..
when mine was back to stock at 130rwkw or whatever it would be i got used to it.. then back at 185rwkw or whatever it is it seemed fast again for like this weekend.. now its not again.. My car is sliding a lot with 40psi still on the tyres though - its kinda fun .. but i guess i better let them down if i want the tyres to last more than another 6 months.
I think 250rwkw would be a fun figure, traction or no traction.. i think that skidpan thing helped a fair bit in learning how to slide more which is good.
You worked how much petrol is going to kill you each week Jet ? :D
Well.. not that i know much.. but i have seen complete RB25 engines with just the stock turbo go for around $3000... so i'd say 3-4k, maybe a bit more with the T04.. you'll sell the turbo easily enough separate if you needed to.
You probably need a new gearbox to go with an RB26 as well don't you?
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
