I bought some 350z track rims the other week, they are 18x8 with a +30 offset. The tyres are 245/45 on the front and 265/45 on the rear.
Grip has improved incredibly since replacing the stock rims/wheels. The tyres are bridgestones potenzas from the top of my head, which although are very noisy seem to be quite good (took car for a drive in the wet the other night and had a lot more traction than I usually do).
The only problem is the rear tyres scrape along the guards when turning into my driveway and negotiating other bumpy/uneven turns. The front tyres can also as well. These problems occur when the weight balance of the car is out of wack, i.e. the car is sitting on uneven ground, suspension is higher/lower on either side.
I want to get into some track work early next year, if I stick with my current imagine taking corners at 80k/phr will cause the tyres to scrape on the opposite side to the way I'm turning (due to body roll).
Brings me to my options:
1) Replace tyres with smaller profile tyres. This will return my speedo to normal (currently out of whack by about 10%) and should stop my scraping problems. Would I get anything trying to sell the tyres? About 60% tread?
2) Roll guards. If my rear guards were rolled it would probably fix the problem there, however even if I roll my front guards I don't think it will stop them from rubbing. This also runs the risk of paint being cracked during the process.
3) Sell the wheels/tyres and replace. If I went down this track I'd want 17" lighter weight wheels, something that looks half decent and doesn't cost a fortune.
When I changed to the 350z rim I felt a slight decrease in stopping / acceleration. The rims apparently weigh 18kg each (without tyres). So a lighter rim would have more than one advantage.
What do you guys recommend?
If I were you, I would just get smaller tyres. If they still rub, roll the guards. If you don't care about the speedo, just roll.
It really depends if you like the wheels or not. Do you regret buying them? If you do, then maybe try a new set of wheels.
Don't regret buying them, got them at a good price. The tyres and wheels fill the guards nicely (a little too nicely it seems haha).
It'll probably cost me around $800+ to replace the tyres on all four wheels.
If I sell the rims (probably get near $1000), I can then spend an extra $800 (total 1800) on new rims /w tyres.
Guess I'll just keep my eyes open, see if any other wheels pop up that I like.
Just get your guards rolled. Should cost about $45 per guard. Might solve the problem, if it doesn't the part of the tyre where it's rubbing will eventually get worn out and stop (assuming that the rubbing doesn't kill your tyres altogether).
Im running 17 x 9 +30 r33 gtr rims on my 32 no scrub when its not super low i.e gap between tyre and guard with 235/45
all round is your car super low?
you could probably get away easily with just bashing in the lip
Yeah the rear guard lips will be ok if rolled upwards.
The front guards won't be I don't think. When the steering wheel is turned to the right or left and the front wheels stick out the side, the gap between the top of the tyre and the guard is very small. Don't even think you'd be able to roll it as the bit that's almost touching is not the "inner lip" area, but the actual outside guard area itself. I'll try and take some pics tomorrow to better show what I mean. This area is only a problem if turning at speed causing body roll.
So I think I might either need to get lower profile tyres, or new wheels altogether. Car is not super low, definitely lower than standard though.
There is an old saying...
"Dont Buy wheels to fit the car. Make your car fit the wheels"
Roll guards, then maybe increase spring rates if It still is a problem (Makes it harder for the tyres to get close to the guards under load, and Still cheaper than new tyres), then drop the bastard another half inch!
Edited by R31 drift pig
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
