i got a set of tomei poncams and for a rb25det, year of make 02/97 series 2, but they they sent me a sent of 09/97 onwards cams and i only relized after i put the inlet cam looked the same, but when i try to put the exhaust cam in the cam angle sensor didnt fit the driver.......................... so wat i want to know do i have to send the inlet cam back or r they the same, dont realy want to take it back out, exhaust cam is ready to send back.......... so inlet the same or not?
Talk to the ppl you brought the cams of in regards to whether they want both cams returned or just the one ..
i had the same concern as your sell as to which cam to buy for a series 2 25t and going by the spec's on the years for the cams you needed to buy the series 1 cam because of the crank angle sensor drive change later in the 97 onwards range.. Not 100% sure if there is difference's in inlet cam's for different year models but just ask them..
brought hks instead and thankfully i ordered to correct ones and they sent the correct ones . cas fitted perfectly ..
Edited by SATO GTS
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
