Item: Nokia N70 Mobile Phone
Age: 1 yr old
Condition: Good
Price: $150 ONO
Contact: Barbs 0403 192003
Comments:
Hey, i got a Nokia N70 phone, used, pretty good condition just needs a new cover since the current one has faded areas on it....other than that its pretty good comes with 512 mb memory card with heaps of stuff loaded onto it....
Please call me if your keen...plz no time wasters
comes with box and all books, instructions, cables etc etc
http://www.gsmarena.com/nokia_n70-1153.php
Cheers
Barbs 0403 192003
$150 ono gotta get rid of it, got a new phone now
Also , will do a swap for a reasonable mp3 player for the car......
https://www.sau.com.au/forums/topic/196491-fs-nokia-n70-mobile-phone/
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
    • Don't assume the AC relay signal from the ECU is +, some models including Stagea use an earth trigger.
    • Hey good to see you on the forums! Haha Considering this cars past with electronic issues I am leaning towards it being a wiring fault somewhere in the engine bay. When testing the ac relay in the fuse box there was no earth trigger. I am probably going to try "bench test" the compressor by giving it direct ground and power to see if i can hear the ac clutch click otherwise I will be pretty sure I have a dead compressor. If it does work then I will be tracing some wiring it seems.
    • Haha, the big brain move is to buy a second set of headlights to clean up or retrofit. I definitely don't have one sitting in a cupboard that hasn't been touched since it arrived. Just have to ignore the intrusive thoughts that suggest the second set is not quite as good as it could be and to buy a third set that the job would definitely get done with
