Courtesy Light Extenders - $20 each plus shipping (or pickup from Cheltenham, VIC). Ph: 0422575485 or 9584 2386
Description of item (comes with instructions and circuit diagram):
The Courtesy Light Extender is designed to keep the courtesy light ON for between 1-15 seconds (can be adjusted) after the door has closed. The light then gradually dims, and finally goes out.
The only cars that you would see this on are, expensive cars that accommodate luxury options. So this courtesy light extender unit is a very affordable and easy addition that will allow you to bring this options to your own vehicle.
When entering the car, the courtesy light will give you enough time to put your keys in the ignition, fasten your seatbelt, check the kids and put your mobile in the holder. When your getting out of the car it will let you lock your car and find your way out of the garage in the dark.
Some circuits keep the light on for a pre-determined time then turn it off quickly but this unit gradually dims the light at the end of the 15 seconds so you know when the time has expired. The Courtesy Light Extender is placed across the door switch, interior light or the interior fuse. It is quick and easy to install.
The wire to the door-switch is easily accessible, either through one of the panels on the door or where it connects to the interior light itself. The unit is small enough to feed through the hole of the temporarily removed door switch. this will allow you to install the unit in the chassis behind the switch.
If the Light Extender has been connected across the interior light itself then it will work for all of the doors on the car. If the Light Extender has been placed on only one door switch, say the driver's door, then it will only work when that door is closed.
The two Contact Connectors included will allow you to connect the leads from the light extender module to the existing car wiring without the need for cutting, stripping, slicing or soldering the original car wiring loom. This will allow you to uninstall the unit as easily as it was installed.
The connection of this circuit will not change or modify the original face-value of the car, because you are adding the unit in parallel with the door switch and not cutting any wires or modifying the original state of the car.
This unit cannot damage, in anyway, the circuit containing your battery, the door switch, the interior light globe or any of its components.
https://www.sau.com.au/forums/topic/19651-fs-courtesy-light-extender-for-cars/
lol - my 1986 R31 Skyline GXE had that... hardly "luxury" but anyway, it was cool :D
So do these work off just any 12v line and drop the voltage over time?? I might have some others uses for these in my car. Let me know..
cheers
not trying to steal ya idea at all mate, as if i wantred to do it i would just spend the $20 and buy one off ya :D
but whats in the circuit? is it just a cap with a pot (as you said its adjustable) ... couldnt see it being too much more than that really?
cheers
shannon
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
