I have searched and not much was reali said about them. Few topics no responses
The guy selling seems a nice guy etc..
but does anyone actually run there turbos??
Whats the verdict on them?
Response?
Power?
How have they lasted?
any luck with them??
cheers
https://www.sau.com.au/forums/topic/196512-hypergear-turbo/
Response?
Power?
cheers
Ill be looking at getting a turbo soon, and i had a search on this forum and found that some are really happy and some really unhappy with HG. Looking at their prices, id rather stick with a garret for a little bit extra cash.
https://www.sau.com.au/forums/topic/196512-hypergear-turbo/#findComment-3516660
YER I AGREE HAVE SEEN MIXED RESPONSES.. BUT WHEN U SAY ALITTLE EXTRA CASH I HAVENT SEEN IT THAT WAY! ooops caps.
the hypergear turbo and oil lines and dump pipe. around $1000 est out put 270kws
what in the garett range makes that and stays in the 1000 range??? none that ive seen even comes close to that
https://www.sau.com.au/forums/topic/196512-hypergear-turbo/#findComment-3516672
I wouldnt buy a journal bearing turbocharger that ISNT both oil and water cooled.
Best bet would be to ring around (yellowpages, search turbochargers) and get quotes for a Rb25 turbo HighFlow job, say "Stage 2" ie big bore to the intake & exhaust housing, 360degree thrust bearing oil and water cooled
see what response / pricing you get. One company out there would surely do them, ie like the Slide highflow Turbos (yes I have one, very happy, but having owned it for a year there would be no way that I would accept a turbo that isnt both oil and water cooled)
and I say thrust/journal bearing as they are roughly 50% cheaper, at least, than a BallBearing equivelant. my journal turbo is above boost pressure at 2400rpm and is at full boost at 4000rpm (1.1bar) from standing start, and hits full boost at 3500rpm when already "on the go" say at 80kmph when I tromp it thru to 110kmph
https://www.sau.com.au/forums/topic/196512-hypergear-turbo/#findComment-3516757
yeah oil only I believe
it's gonna get hot, damned hot; you'll need to be religious with your cooling-down methods
I paid ~ $800 for the slide turbo (not available now) and am damned happy with my value for money
if it lasts another year then yes I'll be satisfied, and hopefully then I can afford a 2k turbo
https://www.sau.com.au/forums/topic/196512-hypergear-turbo/#findComment-3517062
hoiw longs it lasted for so far?
https://www.sau.com.au/forums/topic/196512-hypergear-turbo/#findComment-3517086
Nothing wrong with OIL cooled only turbo's
As you said, Trust range is like that.
yes you get what you pay for.
Everyone was all happy as larry about the Slide Hiflows.
Now there are threads that pop up everywhere (then locked and deleted) about failures and warranty shit.
it's up to you.
But just like you, I can't see a better option for $1K when you get manifold turbo, gate etc etc.
all pretty much ready to go.
EDIT - why not search to see how many people have busted TRUST turbos.
Roy has had a TD06 on his RB20 for god knows how long now.
He's gone through 1 RB20 block but nothing wrong with the turbo.
He's car's seen more track days than most and makes over 250rwkw most of the time.
I'm not comparing HG turbos to Trust turbo's... just trying to show the OIL cooled only-phobia people that it's all ok.
Edited by GTST
https://www.sau.com.au/forums/topic/196512-hypergear-turbo/#findComment-3517100
it's up to you.
yer see thats my thinking....... for 1000 itll be done and on and pushing around 270kws... if it lasts two years ill be happy! plus it has a one year warentee....
but yer dunnO!
https://www.sau.com.au/forums/topic/196512-hypergear-turbo/#findComment-3517109
sounds good then
yeah my thinking for my slide turbo was $800 over 2 yrs is a good deal. got thru 1 yr / 6000kms with it now.
nothing against oil cooling only, just you will HaVe to make sure it cools down properly prior to shut down, with water+oil cooling I must admit I dont worry too much about it.... slow down for last km or so, hit driveway, switch off. with oil only Id be turning on my turbo timer, and that has been switched off since day one of owning the stagea.
https://www.sau.com.au/forums/topic/196512-hypergear-turbo/#findComment-3517131
lol whats wrong wid trust??? not a small brand!
Nothing wrong at all....Just point out the fact their turbochargers are plain bearing and only oil cooled....And damn good items!!!!!!!
sounds good then
f**kin spot on beavon!!!
Edited by Wheezy
https://www.sau.com.au/forums/topic/196512-hypergear-turbo/#findComment-3517144
I disagree Tangles (Surprising hey..)
Since you take it easy on the "last km's or so", wether you have oil only or water and oil cooling makes no difference.
As an example, if you have your slide turbo on and drive off boosty for the last km or so and when you stop at your driveway, say your oil temp is 90 degrees.
same scenario in the oil only cooled turbo will show the same result.
and leting it idle at the driveway for 2 minutes or whatnot will only heat it back up as there is no air going past the factory shitty oil cooler on the oil filter adapter thingy.
if you thrash the bajebus right up to your driveway, you'd cool either turbo down.
if you turned it off straight away, it would seize up either turbo.
https://www.sau.com.au/forums/topic/196512-hypergear-turbo/#findComment-3517165
disagreement is good, mmmm'k?
my slide hasnt seized up yet :)
nah I dont drive like I stole it.
with an oil only cooled turbo a little flashing light would be in my brain (get out!!) saying "cool down first". dont get that with the water/oil cooled turbo - mainly "kill them all" but thats for my psychologist to work on.
https://www.sau.com.au/forums/topic/196512-hypergear-turbo/#findComment-3517188
a little flashing light in your brain? like a robot?
You're a robot?
like ASIMO?
Cool.
Dance Tangles, Dance!!
I still don't believe that it would need any more cool down than any other turbo.
Cooling down essentially means letting the car run so that the oil pump still does it's job to push oil through the engine and turbo.
if you've been cruising along before parking, it requires no more cooling than you woudl for the other turbo's..
ie, park, handbrake up, seatbelt off, get out of door, pull pants up, pull undies out of crack, scratch left nut, adjust position of knob, windows up, turn off car.
https://www.sau.com.au/forums/topic/196512-hypergear-turbo/#findComment-3517263
lol.... nice :laughing-smiley-014:
just asked my tuner and he said oil cooled isnt a negative.. hes looking into them.. ill see what he comes back with
https://www.sau.com.au/forums/topic/196512-hypergear-turbo/#findComment-3517276
    • Looking at finally painting and installing my R32 GTR wing I bought back in 2018. I got two quotes: Quote 1: $880 includes: wing, spare boot, holes welded up prep/paint. Pro: full boot with wing AND hole-less boot with lip i can swap between Con: $$  Quote 2: $330 wing only. Pro: cheaper Con: lose my (relatively) rare no holes sedan boot Also to consider I do plan on painting my whole car at some point "soon" (been saying that since 2018) Anyway Enjoy these All Japan Day 2025 pictures of my 4 door, still rocking the Calsonic Livery! Rolling in Interior shot Matching Peer Pressure Racing overalls are pretty cute ngl. This year was a hard 1990 cut so I got to be over with all the older cool stuff Next to arguably the best car there. A mighty S-Cargo
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
