G`DAY ALL AS TITLE SAID SAUWA have a cruise on saturday 8th dec would like to see some more STAGEA`s on this cruise.if you are south of river MEETING AT GATEWAY`S AT 8,30PM John will be at this meeting point.then to meet the rest at KARRINYUP SHOPPING CENTRE AT 9,30 PM,TO LEAVE AT 10PM.so hope some of you will make it to what should be a great turn out.at the moment we have john,myself,kristie.some come on let`s see you turn up???.cheer`s chuckie.
https://www.sau.com.au/forums/topic/196527-sauwa-cruise/
Charlie - I am going to make it a definate NO for the offer of a ride. I have been able to secure 1st floor atrium seats on the corner of William St & St Georges Tce for the Christmas pageant that night so my kids are going to have quite possibly the best seat in all of Perth for it (not to mention acess to my own cappucino machine for the duration of the event :P
Have fun though
https://www.sau.com.au/forums/topic/196527-sauwa-cruise/#findComment-3517341
Dale, I'm sure your kids would prefer a cruise to a Christmas Pageant :P
HA! In my wildest dreams perhaps!
Hey Paul - did you know that you were actually the last person to ever sit in the back of my stagea? (at the haunted cruise - the next morning it got written off :( )
https://www.sau.com.au/forums/topic/196527-sauwa-cruise/#findComment-3517491
Yep - but due to the insurance situation I have been forced to abandon turbo's for a few years :D Mind you, I got an N15 SII SSS hatch with a SR20DE in it that goes alright, it sure as hell is no stagea, but it will do while I save up for an M35 :(
The back problem is from years ago, everyone concerned walked away from the accident, thankfully, another big :P for Nissan build quality there.
https://www.sau.com.au/forums/topic/196527-sauwa-cruise/#findComment-3517553
Thank`s for that Kirstie,i think their will be 4 of us at GATEWAY`S john,jerome,myself,my nice,hope too see some other`s rock up on the night,hope to be there sbout 8,15 would like to take some photo`s ???.see you then cheer`s chuckie.
https://www.sau.com.au/forums/topic/196527-sauwa-cruise/#findComment-3519680
It was a cool cruise, met some nice new people, and one very new (4 month old) person who looked so at home in the back of her mums red Series 1.
About 60 Skylines and 4 Stageas... red series one (Chuky's niece Heather & baby Sophie), Chuky's Yellow S2, my Bluey and Karl's very kool M35 Axis.
For those that didn't come... you missed a good night. All 3 lanes of the freeway looks great taken up with Skylines and Stageas.
Next time...........
https://www.sau.com.au/forums/topic/196527-sauwa-cruise/#findComment-3521765
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
