Hey ive got an R32 Gtr and i wanna do some sensible upgrades... and need some ideas..
Currently the car is stock other then coilovers, K&N Panel filter, and from what i can tell a Rein Hard exhaust.. (looks like a cat back)
so any ideas on what i could do next? open to all suggestions.. dont really wanna up the boost would like to find the power else where, im new to the turbo scene so want to learn..
also ive been looking at magazines with build segments but has anyone got any HPI mag Articles on the gtr?
https://www.sau.com.au/forums/topic/196529-gtr-modification/
I think you've got most of the basic mods already covered...you can remove the boost restrictor olive which will give you a couple more psi but on old stock ceramic turbos may not be a wise move. Im still new to the rb26 as well but I'd say upgrade to R34 N1 turbos with some 600/700/800cc injectors, a decent size FMIC and chuck a PowerFC in her and you can safely run 260-320awkw which should keep you happy for a while :)
Cheers!
Gagz
So dump + Front pipes.. how much am i looking at there..?
ive seen dump pipes on ebay for $170ish,... whats good? what to look for?
From Memory I paid about $1100 for HKS Dump and Front Pipes, and it will cost you about a grand to have them fitted...it is a bitch of a job!
I also added a Pair of GT2560r turbos's for I think about $2500 (fit at the same time as your Front and Dumps if you chose to replace)
Removed the boost restrictor and Made 315rwHP with a 12.6 QTR at 181kmh
Then I added a PFC ($1100 + dyno $400) upped the boost to about 18psi made 390rwHP and ran an 11.9 @ 190kmh
Doesn't cost $1k to fit dump+fronts, my exhaust bloke has fitted xforce dumps to numerous gtr's from underneath with the turbo's still on the car. Yes it's a bitch but it can be done.
So you'd know how much it costs then?
If so please post a cost so as we dont fill his head with false hope, as so many of these threads tend to do.
I did not get much change from a Local performance shop from a $1000 to have my HKS / Greddy Front and dump pipes fitted as well as 2 x new Turbos, and a quick run up on the dyno :P
I don't know the exact cost no however it is definitely under $1k to fit dumps+fronts. The reason it cost you so much is because you had your turbo's changed also which is labour intensive (8+ hrs which is still well under $1k).
Edited by benm
  • 6 months later...
get your dump pipes, fornt pipes, get a set of cam gears for more zippiness and quicker boost, ofcourse a apexi fc, your not required for a bigger cooler because stock gtr coolers hold over 300kw but if you got heaps of cahs lying around go for a trust or a arc or something, i got a trust one on my gtr and is excellent, just get a good boost controller if you got standard turbos because ntog ood taking the boost retrictor off with those turbos, you said you got filters and your cat back exhaust, put it to about 1 bar of boost and you should happily see about 230-240awkw and it will be a very nice street car just with those mild mods and then later on replace yopur turbos with something better, get some injectors, cams and you will see over 300awkw with a bit off boost and it will be lethal mate
actually wont cost nothing closer to a grand to fit dumps and front pipes,
chasers motorworks are fitting my cousins hpi dump pipes and his tomei cam gears in about a week for $280 but then plus tuning so maximum will cost him $400-$500, 1k is way too much, if you really want you can change your front pipes but ofcourse not the dumps, it will cost you about 1k to fit new turbos, dump pipes, front pipes to be fitted and tuned, i cant see it being more then that, anyway just letting yous guys know,
gl with it mate and i payed $1000 for my hks dump pipes and my bee-r fornt pipes FITTED lol but that was the bloke i bought my r32 gtr off about 2 yrs ago,
cheers tony
Edited by GTRBOS
You got a budget?
1st of all get new Dump and Front pipes cause the stock R32 GTR ones a terrible. The Diametre is tiny and very restrictive.
If you don't want to boost up the turbos then exhaust is pretty much it. You can install twin air pods but I think most ppl here might say stick to your K&N Panel filter.
Keep your stock intercooler, blow off valve, don't need to upgrade these until heavy modification.
You could upgrade to a Lightweighted Flywheel, it can help with take off + upgrade to a heavy duty clutch.
why not just change them yourself? the bolts are pricks to get to and much wd40 will be used... oil even if its bad.. but otherwise... it wont be that bad.
just make sure you have gaskets ready to go on with your new parts and your great...
provided you have stands / role on's are easier, get under the went and remove the old exhaust... that is unless you pussies cant deal with a couple of bolts... shit a t25 isnt as bad to undo as t3's... they suck... >;p
be extremely careful not to snap the bolts.. if it starts to round.. just stop.. if you dont have a good set of tools don't bother i guess is the moral.
we arent talking about gear sets inside the gear box here... it's a piece of piss to pull of an exhaust.
fair enough..
well i recently discovered that it had a dodgy little cat converter on there restricting the shit out of it.. so thats been upgraded today.. and my mate thats doing it is Phat Pipes in Brisbane here (Excellent Reputation) anyway hes also giving me a quote to do the rest of the exhaust ie. front pipes and dumps..
but tell me whats the real difference in dumps and front pipes from brand to brand..
as ive seen so many different ones including cheap shit on ebay for $200.. all 3inch mandrel..
whats the difference?
it all depends what kind of material it is, some stainless is really shit but if you go for the hks or sopmething they are much better but in power wise they all do the same shit but its all aboutn reliability, dunp pipes dont give a massive difference but when you change the cat back and the cat or even get it highflowed or something(bash the cat out) that makes alot of difference but it is good to change the whole exhaust while your at it, i wasnt going to change my dumps until i bought new turbos but the bloke i purchased my car off had them there to put in this other gtr but i begged him for them and he said $700 and i negotiated with him so at the end of the day he supplied my hks dumps and also i bought bee-r front pipes which are worth about $600+ and i got it all for 1k fitted, i saved at least $1k just there, but mate just pay couple hundreds more and get yourself some good dump pipes, my cousin bought hpi dumps off one of my mates for $300 but they are second hand but dont seem to have any wholes or anything so even good second hand ones bro they all do the job mate
less restriction i really think mate, exhaust is probably the most important mod to change on any turbo car
+1
It frees up the exhaust flow allowing it flow quicker in resulting the car performing a lot smoother.
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
